7 members (DJC, tommog, Tweed19er, dogmog, RichardV6, James B W, OZ 4/4), 269 guests, and 36 robots.
John V6 68
+8Rich 67
DaveW 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Topics48,345
Posts813,047
Captain Morgan, IRWIN
gcarguy Offline OP
I need to do oil change.
Is 10 40 alright or should it be 10 50 ?
Do I use same oil for tranny?
Lucas eng treatment was suggested for tranny to keep seals from withering. Any thoughts.
Thanks
71 Plus8 Yellow/Blk
57 Morris Minor Trvlr 1098cc
93 MB 500E
66 MB 230SL
48 Chev Fleetmaster Conv LS1
Back in the day when the Rover V8 was a new engine in UK , it was fed on a diet of 20/50, and one of the UK's best known engine builders of this unit still recommends it today.
However you are probably aware that this is a "flat tappet" engine , and needs quite high loadings of ZDDP. It is probably more important that you choice of oil contains high levels of this additive than which grade of oil you choose. I have used a Millers Classic 20w/50, but the dealers tend to use a 10w40 semi-synthetic.
The gearbox oil is another area of debate. This box is incredibly strong and it is probably more important that there is sufficient oil in it , rather than worry too much about the grade. Originally we all used a 80 or 90 weight gear oil, but if the box is baulking a lot some users went for a straight 30 engine oil to decrease the fluid friction, I believe that some modern ATF fluids have also been used with success, but I have not tried them.
Andy G
1999 +8 , Indigo Blue.
