0 members (),
258
91
Topics49,847
Posts837,389
Posts: 614 Likes: 22
Posts: 614 Likes: 22 |
I got round to looking at the brake pedal height the other day to make it easier to "heel and toe". Removed pedal bar and then adjusted the yoke on the M/C push rod. I managed to get 4 to 5 mm at the push rod which is a lot more at the pedal head. While the lot was on the bench I made a weaker brake pedal return spring as, IMHO the one Morgan fit is far too strong. I would still prefer to lower the brake pedal a tad more but for the moment it's OK and much better for heel and toeing. A couple of pics. Cheers John
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Taking the pedal rubber off and sticking on some skateboard decking none slip tape would reduce the brake pedal height feel. I have it on my brake and clutch as it also increases the gap between the pedals for my size 12's. It's been on for 2 MOT's now and still not worn through. About £10 a roll and enough to do about 20 pedals, several friends have been given a piece ;-).
Posts: 2,814 |
Slight thread drift here but where can I get a Teflon-lined throttle cable? I have seen some available for karts, but they seem rather expensive.
Gerry
Posts: 486 |
Taking the pedal rubber off and sticking on some skateboard decking none slip tape would reduce the brake pedal height feel. I have it on my brake and clutch as it also increases the gap between the pedals for my size 12's. It's been on for 2 MOT's now and still not worn through. About £10 a roll and enough to do about 20 pedals, several friends have been given a piece ;-). Snap!
Cain
Wolf Cafe Racer 4/4 Sport
Posts: 486 |
Slight thread drift here but where can I get a Teflon-lined throttle cable? I have seen some available for karts, but they seem rather expensive. I used these chaps for all my Motorbikes http://www.venhill.co.uk
Cain
Posts: 2,814 |
Thanks Cain, they have a suitable range.
Gerry
Posts: 2,814 |
Another useful website- thanks John.
Gerry
Posts: 28,894 Likes: 351
Posts: 28,894 Likes: 351 |
Board tape - great stuff (thanks Colin)! Will wear out the soles of your driving shoes faster than it wears on the pedals
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
Paint the indent in the throttle pedal John for that OCD feeling of total satisfaction!
