0 members (),
359
87
Topics49,847
Posts837,389
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
So....is blacktop full fat and silver topped semi skimmed.....or vice versa?  It took me a while to get that I was about to post 'eh?'
Posts: 155 |
A few years ago I visited Chas Windridge of Mogsport fame to get some AVO shocks for my +4 T16, and he suggested that to get much better breathing I should remove the restrictor plate that's spot-welded about half way along the internal pipe of the silencer. (This plate has an approx 1/2inch hole in it, so reducing the effective diameter of the exhaust pipe considerably). The method he suggested sounded rather brutal – knock seven bells out of it with a long, hefty steel bar – but I tried it, and it worked! It's made a big difference, too. The engine is much more willing to rev, and the exhaust note has a bit more of a burble. And all this for zero cost! Makes you wonder just what a 'sports' silencer is, though...?
Sid
Ex 2014 3.7 Roadster in Ferrari Le Mans Blue Ex Indigo Blue '99 +4 Ex MogMMX Innovations winner
Posts: 14,009 |
So....is blacktop full fat and silver topped semi skimmed.....or vice versa?  It took me a while to get that I was about to post 'eh?' Subtle eh?
Posts: 3,560 Likes: 12
Posts: 3,560 Likes: 12 |
No Stewart, the Zetec has a left side exhaust and the Duratec a right side exhaust. My "Blacktop" Zetec is as Stewart describes and the exhaust runs along the driver's side. Very odd, I had a Blacktop in my Caterham, before changing it for a 2.3 Duratec, with the exhaust on the offside, and that had the exhaust down the nearside, the Bl**dy hole is still there in the aluminium side panel.
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Indeed "very odd" words also used by Tim Ayres when he was having a good look at my 4/4. Though, apparently, the exhaust layout is the normal for Morgan black top Zetecs The exhaust manifold on my car is on the nearside, but the exhaust is then routed under the engine, through the offside chassis rail and then proceeds along under the offside running board. Remind me to show you when we next meet up. It might also be described as standard Morgan factory engineering?
Bud 4/4 "Stanley"
Posts: 564 Likes: 8
Posts: 564 Likes: 8 |
Left hand exhaust manifold feeding to a drivers side exhaust is indeed how the Blacktops were built. The following link to Librands shows pictures of my previous car after the standard manifold and cat were replaced. If you click forward you can see how the exhaust system is routed. http://www.librands.co.uk/products-view-109.html
Andrew 'Alice' 2013 Duratec Plus 4. Pearl Blue
Posts: 5,210 |
A few years ago I visited Chas Windridge of Mogsport fame to get some AVO shocks for my +4 T16, and he suggested that to get much better breathing I should remove the restrictor plate that's spot-welded about half way along the internal pipe of the silencer. (This plate has an approx 1/2inch hole in it, so reducing the effective diameter of the exhaust pipe considerably). The method he suggested sounded rather brutal – knock seven bells out of it with a long, hefty steel bar – but I tried it, and it worked! It's made a big difference, too. The engine is much more willing to rev, and the exhaust note has a bit more of a burble. And all this for zero cost! Makes you wonder just what a 'sports' silencer is, though...? Interesting. Anybody know if the sigma pipe will have a restrictor plate in it and if so tried to remove it?
Posts: 14,009 |
My 2010 example had a straight through silencer,,,no baffles. The Roadster originals on Nero were baffled.......baffling!
Posts: 676 |
Very odd indeed, I cant see the advantage of routing the exhaust under the engine to exit on the off side. Surely it would have been simpler (cheaper) to route it out of the near side?
1989 911 Porsche Carrera Land Rover Series Defender 90 SW
Left hand exhaust manifold feeding to a drivers side exhaust is indeed how the Blacktops were built. The following link to Librands shows pictures of my previous car after the standard manifold and cat were replaced. If you click forward you can see how the exhaust system is routed. http://www.librands.co.uk/products-view-109.html Interesting There must have been a good reason particularly when the silver top before it was all down the left Was it to do with stricter emissions?
