0 members (), 253 guests, and 81 robots.
+8Rich 77
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,873
Posts837,706
Hi Everyone
Many thanks for these helpful responses.
Yes, the engine is a Rover M16.
I have to say that I did not check the relay. The pump was not spinning but there was power at the terminals to the pump when I turned the ignition on. So I concluded it was not the relay but the pump. Furthermore, the fuse to the pump had blown and I felt that an attempt was being made to run a pump that was jammed, which pulled too much current. Finally, having removed the pump I put 12 volts across it and it did not spin; it made a feint noise as though it was jammed. I thought this supported my conclusion that it was the pump.
Was my thinking OK or should I investigate the relay? How do I check if the relay is OK?
Many thanks in anticipation.
If the pump has power but is not providing fuel I'd say the pump was stuffed... smile
