1 members (Kolvites),
278
Posts837,990
Posts: 112 |
I have a problem with the handbrake on my 1938 Series 1 4/4 - it applies its self each time I use the food brake. The system works on a (new)common cable with the foot brake with the handbrake connection "fixed" to the cable. I'm at a loss to see how the footbrake can work with this setup without applying the hand brake at the same time. Your help urgently required. Many thanks in anticipation
1967 Plus 4 Drophead coupe with a TR4a engine
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
Does the handbrake lock in when you push the footbrake?
Posts: 145 Likes: 1
Posts: 145 Likes: 1 |
My 1947 4/4 Cable brakes just twitches a bit doesnt come on. its just a question of perpetual adjustment I guess.
Posts: 112 |
Hello and thank you for your reply. Yes, the handbrake locks on the serrated quadrant when the foot brake is applied
Posts: 112 |
Thank you Chris. This could be the answer but to adjust the cable, I have too remove the handbrake as the cable connetor at the base of the handbrake lever is a fixed fitting on the cable and doesn't rotate individually
Posts: 145 Likes: 1
This could be why the world went over to hydraulics !
Posts: 112 |
Yes Chris. You could well be right. It seem strange that some lesser (non-sports)cars were fitted with full hydraulic braking systems well before Morgan adopted them and could still market their product very competitive, and often cheaper prices
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
Even Rolls Royce used mechanically operated rear brakes until 1955.
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
A 30's had mechanical rears, and possibly A35's.
Posts: 112 |
Thanks Guys. Great info but we are drifting a little from the core of the original message. If anyone has experience of the handbrake of early series 1 4/4's applying itself everytime the footbrake is pressed, I would appreciate input of their solution to the problem
