7 members (+8Rich, IcePack, Ian Wegg, SteveT, scortroadster, riri, simon8201), 315 guests, and 35 robots.
+8Rich 93
John V6 49
Posts837,989
#300381 27/08/15 10:43 AM
Sinbad Offline OP
I have a problem with the handbrake on my 1938 Series 1 4/4 - it applies its self each time I use the food brake. The system works on a (new)common cable with the foot brake with the handbrake connection "fixed" to the cable. I'm at a loss to see how the footbrake can work with this setup without applying the hand brake at the same time. Your help urgently required. Many thanks in anticipation
1967 Plus 4 Drophead coupe with a TR4a engine
Does the handbrake lock in when you push the footbrake?
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
My 1947 4/4 Cable brakes just twitches a bit doesnt come on.
its just a question of perpetual adjustment I guess.
Sinbad Offline OP
Hello and thank you for your reply. Yes, the handbrake locks on the serrated quadrant when the foot brake is applied
Sinbad Offline OP
Thank you Chris. This could be the answer but to adjust the cable, I have too remove the handbrake as the cable connetor at the base of the handbrake lever is a fixed fitting on the cable and doesn't rotate individually
This could be why the world went over to hydraulics !
Sinbad Offline OP
Yes Chris. You could well be right. It seem strange that some lesser (non-sports)cars were fitted with full hydraulic braking systems well before Morgan adopted them and could still market their product very competitive, and often cheaper prices
Even Rolls Royce used mechanically operated rear brakes until 1955.
A 30's had mechanical rears, and possibly A35's.
Sinbad Offline OP
Thanks Guys. Great info but we are drifting a little from the core of the original message. If anyone has experience of the handbrake of early series 1 4/4's applying itself everytime the footbrake is pressed, I would appreciate input of their solution to the problem
