Topics49,844
Posts837,371
Posts: 21 |
I have a Roadster 2010 and problem with the fuel tank or fuel pump. When it is about 20 liter left and i turn left the engine allmost stoped. When I go straight the motor functions is normally again. How to fix this problem? The fuel gauge dos not work either.
Posts: 1,415 |
Hi Hans
I would suspect that the fuel pump retainer inside the tank has broken loose, and that the pump is moving around inside the tank. As the fuel sender unit for the gauge is attached to the fuel pump this would also explain the gauge not working correctly
Simon @ Mulfab
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 21 |
OK, I take a look and see.
Posts: 21 |
The problem is solved.
Petrol pump had fallen to the bottom of the tank. Incorrect bracket mounted in the manufacture.
Posts: 21 |
Posts: 1,415 |
It's nice to be right sometimes..... :-)
Simon@sifab.co.uk
Simon @ Sifab.co.uk
