9 members (deano, Julian BB, Alan Patterson, Image, Roady, Clipper, RichardV6, Hamwich, Pittsartist),
279
74
Topics49,859
Posts837,511
Posts: 86 |
Could anybody tell me what speed my 2015 M3W should be travelling at in 5th gear if the rev counter reads 2000 rpm. I'm suspecting a faulty rev counter as I am apparently doing 80mph. Also the ECU appears to be limiting my revs to just under 3000 rpm. I rang my dealer last week and arranged to take it in to have the ECU setting checked, but it's pointing to a faulty rev counter.Was wondering whether anybody else has experienced this?
0000oooooooo
Posts: 6,538 |
My Speedo ran 5mph over the actual speed.
I would have thought that on what is just over tick over you are v unlikely to be doing 80. More like 45/50 max.
Neil
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
3,000 in 5th is just under 70 so something's not right
Red Leader
Posts: 181 |
From memory I think the ecu has a built limiter until a run in period or mileage has been completed
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
The speedometer and rev counter signals are both processed through the ECU. Suspect indications combined with revs being limited to 3000 rpm points to an ECU problem, I would guess.
Posts: 22,360 Likes: 353
Posts: 22,360 Likes: 353 |
I had a faulty Rev counter on my Plus 4 which wouldn't go above 1500rpm. It was impressive on the Motorway though!
Posts: 1,004 Likes: 31
Posts: 1,004 Likes: 31 |
Last weekend I noticed that speedo indicated 10 km/h too high systematcally. In my 2009 Roadster I typically use rev counter for speed, when in 5th gear. When I stopped speedo indicated 10 km/h. Switched off contact and restarted. This solved the offset. All kind of different Mogs seem to have rev and speedo idiosyncracies. Kind Regards, Bert
2025 Plus Six - 1909 2009 Roadster 1983 4/4 4str Board member Morgan Sports Car Club Holland ('21)
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
The speedo/tach are all running from/through the ECU. Digital stuff occasionally loses its mind and a simple power off/on can do wonders!
At least it's not Lucas!
Posts: 782 |
Sounds like it's only showing half the rpm as though it's only picking up one cylinder's input... So may not be the rev-counter, may be the sender or pickup that's faulty.
Posts: 582 |
I thought the speedo and tach were just for show anyway?
