Topics49,848
Posts837,401
F182CGJ Just Getting Started
Posts: 31 |
Supplied the wrong petrol filler pipe by Harpers who seem unwilling to change it to the correct 2 seater pipe...or issue a refund. The part supplied by them is a straight pipe for a 4/4 four seater and in no way will it fit. I have now obtained the correct pipe which has a slight bend. Advice please on installation after I have cut it to the correct length. Many thanks
John Humphreys
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
John,
I recently replaced my filler pipe on the 89 Plus four 2 str, having ordered the bent one from BHM. Two things : the pipe needed to be shortened and so I made a simple template from paper. In order to stop filling blowback I made it as straight as possible and now have a fast fill at the pump. The other thing noticed was how corroded/cracked the exterior was and how undegraded the interior. I use 98 unleaded. Vaseline around the tank pipe and the filler pipe will help but it can be a bit of a struggle.
Posts: 132 |
If you are within 14 days of delivery, you can refer Harpers to the distance selling regulations (assuming you bought via phone / website) which stipulate that the seller must refund the goods and postage, no matter what the reason for return.
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
Vaseline around the tank pipe and the filler pipe will help but it can be a bit of a struggle. Understatement of the century! When I did mine I though I was never going to get it to go on, it was a complete pig. Plenty of lube and plenty of patience required.
Understated is my middle name - oh. no. it's not I was given the name of a literary confirmed bachelor- what was my mother thinking?
Posts: 6,538 |
If you are within 14 days of delivery, you can refer Harpers to the distance selling regulations (assuming you bought via phone / website) which stipulate that the seller must refund the goods and postage, no matter what the reason for return. I had fully forgotten that Law - thanks for reminding us all a good one! I do buy a lot on the www and never have problems ( at the risk of tempting fate!) but good to know.
Neil
Posts: 5,464 Likes: 171
Posts: 5,464 Likes: 171 |
Just went to look up the Distance Selling Regulations and they were replaced by the Consumer Contracts Regulations in June 2014. http://www.which.co.uk/consumer-rights/regulation/consumer-contracts-regulationsEssentially the same - the Which page link gives a very straightforward explanation. They also include online / telephone purchases of services - e.g. Gym Membership.
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
1972 4/4 2 Seater
Nope, try being led Up the garden path.
