0 members (), 424 guests, and 66 robots.
+8Rich 83
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,427
#304152 12/09/15 06:56 AM
Matty Offline OP
I am experiencing a scuffing sound from the rear on sharp slow left hand turns.
I have checked the wheel spindle and adjusters and all seems fine.
Any ideas out there?
Matty #304163 12/09/15 07:40 AM
Belt on the sprocket due to flexion in the chassis or drive train maybe
Mark - No Longer driving
Matty #304176 12/09/15 08:16 AM
Matty Offline OP
Thats what it sounds like.
Matty #304191 12/09/15 09:25 AM
Matty Offline OP
There is a small mark on the tyre as if the belt has rubbed a liitle
I think it may be tryre deformation. I fitted a standard profile bridgestone.
Gonna pump it up a little and see waht happens
Matty #304396 13/09/15 06:12 PM
Matty, I forget what year your car is. Check and see what color the hub is. If its silver its the old one and you may need to swap it out for the new one. I have a 2012 and had that problem. I replaced hub with the new BLACK hub which has slightly different dimensions and belt rubbing on tire is no longer a problem
Matty #304466 13/09/15 09:38 PM
Matty Offline OP
Thanks hbatts
I have the later hub so rekon it must be the tyre deforming
