0 members (), 297 guests, and 79 robots.
+8Rich 76
DaveW 52
Topics49,867
Posts837,614
Moggo
#305554 18/09/15 11:48 AM
tom+4 Offline OP
My morgan +4 2008 is 4 cm lower on the drivers side than passenger side
And i intend to change the leaf springs this winter
Question
I live in belgium (sorry about my lack of the english language)
Where to,order the leave springs
Witch ones to order 4 or 6 leaves or rear leave springs from a 4 seater
id would like them to buy the leave spring in england but where ?
Do they exist aftermarked or order them in malvern ?
Witch price to expect
Difference in riding hight ?
Difficuty , is it doable yourselfe without in a normal garge with jackstands ?
Gr tom
Tom+4, There has been a considerable amount written about that problem on this forum but can I suggest you ferret out the excellent posts by DaveW (and others) on TM. The job is a fiddle but not impossible with space and basic tools - just follow the DaveW format.
Good Luck
Tom+4
Here is how I did it.
I went for 4 seater 4 leaves sourced from Mulfab, a supplier who know about suspension.
The new springs give a slight increase in ride height. Note that even new springs vary in camber.
You can do the job with basic tools, but it is strenuous.
Google translate:
Voici comment je l'ai fait .
Je suis allé pour 4 places 4 feuilles provenant de Mulfab , un fournisseur qui connaissent suspension.
Les nouveaux ressorts donnent une légère augmentation de la hauteur de caisse . Notez que même les nouveaux ressorts varient en carrossage .
Vous pouvez faire le travail avec des outils de base , mais il est intense .
http://www.talkmorgan.com/ubbthreads.php/topics/206231/1
Originally Posted By DaveW
Tom+4
Google translate:
I should have added that the same as Dave I sourced my springs from Mulfab and followed Peters advice and it worked perfectly.
BR Colin
Tom+4, I send you a PM.
Gert,
Metallic Grey '89 +4, with '95 T16, chassis# M7777, Suplex RS
E
E
I have a 2 post lift and as a general rule and not Morgan in particualar at least 70% of cars are at least 2cm lower on the drivers side front than the other wheels.
tom+4 Offline OP
Mail sent to mulbab ,no answer so for
What is the price range ?
tom+4 Offline OP
Eddy
It is not the front side it is the rear side
Morgan has the excellent new style Suplex rear springs available from the shop.
http://www.morgan-motor.co.uk/mmc/shop/i...af-springs.html
Back in 2013 my +4 4 seater springs cost £196 from Mulfab.
Transformed the handling and ride.
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
