8 members (Lordofthewings, RichardV6, Steve +8, TalkMorgan, Image, aerotaff, uvk33n, +8Rich), 284 guests, and 96 robots.
+8Rich 86
Sagging Hood
Topics49,854
Posts837,449
#30503 05/06/09 06:40 PM
pref a 1.8 Duratec, or a 1.8 Zetec, with ecu (whatever that is!) and manifold.
Y
Y
Why you want this engines?Every breakers yard have 1000s of them,category B damaged cars for £50 every day on auction,with this engines.Install 2L cossie turbo.At least its proven,real sport engine,or RB 26T.Choose the best.
Yuri #30642 08/06/09 10:54 AM
<<<Why you want this engines>>>
Because I know what I want!
Yuri #30667 08/06/09 07:02 PM
Hi mudplugger
If you take a look at Raceline, you can get a brand new, crated 2.0 blacktop zetec complete for £750 in standard tune, which needs an ECU but has everything else, or in any state of tune you desire for quite a lot more £££! Manifold would be extra.
Nigel
I believe that Yuri is suggesting the most economical route is to consider buying one from a professional breaker. As these engines were used in a myriad of Fords, it is a worthy option.
A site such as this one can be a good starting point
http://www.breakeryard.com/partfinder.aspx
[I have no link to this site, simply attempting to assist smile ]
nputtick #30720 10/06/09 02:35 PM
Ah... you want to stay in class 3 not 7!!
Right... 1800cc it is then. Zetec E
Not sure about 1800 Duratec? you'd need to do quite a lot of modification to get that in I think. Exhaust is opposite side for instance.
Zetec E would be a silver top, early ST170 engine would be the easiest swap ready to go and tuned for 170 bhp, saw an advert that took one of these engines to 400bhp so loads of scope without the need for major engineering - unless someone knows better
Chris444
chris444 #30933 15/06/09 06:08 PM
Originally Posted By chris444
Zetec E would be a silver top, early ST170 engine would be the easiest swap ready to go and tuned for 170 bhp, saw an advert that took one of these engines to 400bhp so loads of scope without the need for major engineering - unless someone knows better Chris444
I think that is what Sprinty did to his??
waiting
Phil Egginton
1979 4/4 4 seater
SpeedMog #30940 15/06/09 07:37 PM
Indeed it is- ST170 a great engine Richard but as you know 1998 cc. I can't believe you will get 400 bhp from a Zetec 2l without turbo charging or supercharging.
St170 engines are going for about £700 on e-bay. Good choice and with an Omex ecu about 150 bhp at the rear wheels!
Morgan 4/4 Sport Competition
SpeedMog #30941 15/06/09 07:57 PM
Yep...
