2 members (Plus Four Guy, TeddyAds), 355 guests, and 62 robots.
+8Rich 83
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,427
#306691 22/09/15 08:49 PM
Matty Offline OP
Has anyone got a definitive answer on what what the modification kit contains and what mods are actually required
PJB Offline
What engine? PJB.
Originally Posted By PJB
What engine? PJB.
Come on, concentrate at the back.
Its in the 3 wheeler section so is a S&S engine, there have been lots of comments that the crankshaft nut comes undone and punches its way to freedom through the timing cover. There is rumoured to be a modification to prevent tho hapening but for some reason seems to be a well kept secret as to what it is.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
PJB Offline
Didn't Williams Automobiles do something on this? Or am I mistaken again or just leaping in where fools fear to tread. I'll get back to what I am supposed to be doing to be safe. PJB.
What I assume is this mod has been done to mine after it spat out the drive pulley bolt recently.
I didnt see the kit before fitting, but I know at minimum it comprises new bolt assembly ( hex head , not torx ) drive pulley and I think idler pulleys.
Also .... the replacement timing cover has the spacer cast in ( no washers !! ) , two forward facing slits just under the horizontal ridges on the front face , and a small gap at the bottom. All to increase airflow I guess. If I can get out to the car I will post a picture.
Picture will be excellent,...curious to see the official mod sherlock
Cheers,
Georges
