Topics49,868
Posts837,651
Posts: 431 |
Hi - I keep having an intermittent problem with my main beam light not functioning? Some time it does and some times it takes a couple of seconds to light up. I thought the dealer had fixed it but apparently not. Anyone else had this and if so what cured it?
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Does it have a relay fitted?
Richard 1976 4/4 4 Seater
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
Had this on both lamps at different times, each time it was a bad earth, cured by running a fly lead from bulb plug to a lamp bucket screw. Easier option than trying to find the problem in the loom.
1993 T16 +4 Lancia Blue.
Posts: 431 |
Not sure if it has a relay - its a 2014 reg 2015 car probably one of the last before GDI. Are these lights all linked to a circuit board? It came back on again this morning - so its a frustrating intermittent fault. If it is a circuit board I guess it would make it more difficult to earth?
Posts: 131 |
Check the bullit connectors under the front wings that was the cause on my 2010 Duratec. Don't know if yours still uses them.
Tony
Claret Red +4
