12 members (MartinB60, Grumpy2, Paulxj, BobtheTrain, ScotiaSteve, DickJ, Moggo, Vansrv6, Alan Patterson, DaveW, RichardV6, Luddite),
372
53
Topics49,860
Posts837,493
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
On the Aero the tyre would rub and the only option would be to cut away part of the front splitter. I'm guessing the Plus 8 would be the same The +8 has no splitter, there is masses of space in front to the wheel... As the profile is in both cases 35% the difference in sidewall heightbetween 225 and 235 is 3.5cm, ie. the 235 wheel is is 7cm taller than the 225, based on using this calculator: . Calculator But that is almost 3", there is little clearance between the wheel and wing edge so it might catch the wheel arch on lock....
Posts: 782 |
Someone removed the 'who did it' from my post I think... If it works this time it was Brands Hatch Morgans who sent the wheel away but I don't know who they sent it to. Great job - my wheel was MUCH MUCH worse than yours and now looks perfect.
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
As far as I am aware plus 8 and Aero wheels are made by RAYS of Japan and imported by Co-ordsport in Tipton, West Midlands. Several dealers nationwide including Demon Tweeks. All the above have websites, hope this helps!
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Mr Fezza Talk Morgan Expert
Posts: 2,825 |
On the Aero the tyre would rub and the only option would be to cut away part of the front splitter. I'm guessing the Plus 8 would be the same The +8 has no splitter, there is masses of space in front to the wheel... As the profile is in both cases 35% the difference in sidewall heightbetween 225 and 235 is 3.5cm, ie. the 235 wheel is is 7cm taller than the 225, based on using this calculator: . Calculator But that is almost 3", there is little clearance between the wheel and wing edge so it might catch the wheel arch on lock.... It can't be 3 inches difference between a 225 wide and a 235 wide tyre! 235 x .35 is 82mm 235 x .35 is 79mm So that's a 3mm difference. Not 3cm To get a 3cm difference you'd need to go from 225to a 335 tyre width!
-------------- Maxxed out!
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
As far as I am aware plus 8 and Aero wheels are made by RAYS of Japan and imported by Co-ordsport in Tipton, West Midlands. Several dealers nationwide including Demon Tweeks. All the above have websites, hope this helps! Very helpful - thank you very much... They look like Volk Racing wheels off page 28 of their huge catalogue (caution, large file): http://www.rayswheels.co.jp/DB/catalog/2015/pdf/2015SUMMER_all.pdf
+8 4.8
Posts: 14,009 |
As far as I am aware plus 8 and Aero wheels are made by RAYS of Japan and imported by Co-ordsport in Tipton, West Midlands. Several dealers nationwide including Demon Tweeks. All the above have websites, hope this helps! Very helpful - thank you very much... They look like Volk Racing wheels off page 28 of their huge catalogue (caution, large file): http://www.rayswheels.co.jp/DB/catalog/2015/pdf/2015SUMMER_all.pdf I've spoken to John Burbidge and the wheels are supplied by Speedline and are Corsa.
Hi Mike - yes Steve Morris replied and was very helpful.... although I still didn't discover who made them.  But he offered to help - speedy response and can't be faulted. Jay, you're a star - thanks so much for taking the time out. I will research away now I know! Virtual pint to you.
+8 4.8
Yes confirm MMC use both RAYS and Speedline ! The Speedlines are 'Corsa' but not shown on their website. I don't know how to upload a pic (!) but the details are:- MR01 FMR01--1S 8.5J x 18H2. ET26.5 5 x 114 00001658 Silver. Steel lip. 270/12 (1CPG MORGAN01 D031)
As far as I can see 18'' wheels are Speedlines, 19'' are RAYS
I confirm the 19" "Aeromax" wheels are Rays, made in Japan and forged, not cast. So probably horribly expensive.
Posts: 98 |
I have RAYS on my Donkervoort GTO, 18 in the front and 19 in the rear
A set of four wheels costs 12.000 Euro.....
RAYS doesn t supply those to the public, just to the factory as dimensions are specific
I bet the agreeement with MMC is similar somehow
