0 members (),
315
32
Posts837,276
Posts: 33 |
The blue enamel paint infill on my +4 bonnet badge (the one over the radiator) has mostly flaked away.
Does anyone know the right colour to use to restore it? Is there a preferred paint type?
Plus 4 2-seater / 2.0 Duratec / 2011 / Amazon Green
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
I would go for Humbrol modelling paint. Cheap as chips and you can mix & match. http://www.ebay.co.uk/itm/HUMBROL-Enamel...=item4d2d335705Midnight blue gloss looks quite close.
Posts: 2,583 |
I used car paint - but changed it to body colour so the badge matches the car. I drop the paint in with a cocktail stick & push it around to fill the gaps. I think also that if I did it again I might experiment with glass paint which should give a shiny translucent effect.
Posts: 832 Likes: 28
Posts: 832 Likes: 28 |
Whatever paint you use, finishing off with a two pack epoxy resin varnish gives a finish close to real glass enamel and gives a really tough non yellowing seal. Available on ebay from suppliers of fishing rod building supplies. Used for sealing rod whipping.
1993 T16 +4 Lancia Blue.
Posts: 33 |
Thanks everyone - Humbrol it is.
Posts: 970 Likes: 1
Posts: 970 Likes: 1 |
Humbrol worked for me and a very fine squirrels hair paint brush
Magwa 1950 Allis Chalmers B tractor 2000 Porsche boxster 2014 Skoda yeti 4x4 elegans
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Posts: 6,954 Likes: 115
Posts: 6,954 Likes: 115 |
What's got a hazelnut in every bite? Squirrel s**t.
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
I have been using my tins of Beaver wax this summer got everyone I did perfection to the touch.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Beavers nuts are waterproof hence swim on their bellies. Squirrels on their backs. Beavers don't mind wet nuts but squirrels do...
