Topics49,871
Posts837,679
Posts: 98 |
The passenger side inertia reel seatbelt on my 2002 4/4 is jammed in the fully 'out' position. I suspect that I may have to replace the unit. Do any forum members know where these can be sourced and whether it is a 'standard' item or a special one for Morgans?
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
You can gain access from the spare wheel well. Try jiggling the webbing, whilst applying gentle tapping with a Thor leather hammer. You may escalate to copper or soft faced wheel hammer with care. It should 'shock' into retracting.
Posts: 1,569 Likes: 12
Posts: 1,569 Likes: 12 |
Manxmog, I replaced the belts in my Plus 8 last year beacuse I wanted ones with adjustable straps rather than fixed stalks (because they happened to line up perfectly with my hip bone). I got them from a local Securon dealer. Try www.securon.co.uk.Steve L
Steve L.
1996 Plus 8 N22 MOG
Posts: 98 |
Thank you both for your advice - much appreciated. Maybe the hammer first to see if it will be shocked into retracting !!!
Posts: 102 |
Manxmog, Had exactly this problem with my 2001 4/4. Got BHM to get a new one in in case they couldn't fix the existing one. Booked it in, and in the end they fixed it with a "special tool" that Keith had made up - a common problem apparently. They fixed the other belt too in case that failed at some point. Cost me an hour or so.
Kevin Black/tan 4/4 sport
Did his special tool have a wooden shaft and a large heavy head by any chance......
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
I think you will find one in the special tool catalogue under listing for "Birmingham Screw-driver"
Posts: 98 |
Thanks for your comments. Have lined up a replacement belt in case the Birmingham screwdriver fails! Wonder why belt failure is a common problem? It doesn't seem that common in other cars.
