4 members (Detlev V6, Ian Wegg, Gordon D, bmgermany), 375 guests, and 40 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,343
Christoph
V
V
My +8 has had an unfortunate liaison with a little old lady, who launched an unprovoked first strike on the right rear wing whilst the car was parked.
It is an insurance job (wing and wheel). However, things have ground to a halt as, according to the Morgan dealer who is sorting it, the factory have said they are not supplying new steel wings any longer, only alloy. I am told that the alloy wings have a slightly different profile, which will be noticeable. The dealer is chasing contacts regarding alternative suppliers of steel wings, but in the meantime, does anyone have any ideas/thoughts regarding sources?
Thanks
Dave
vbalddave
Red 1993 +8 4.6
North Yorkshire
I would give Steve Barnes a call at Vintage Sheet Metal. He's just moved, his number is 01531 671148
E
E
You could try Steve ate VSM, (Vintage Sheet Metal) he makes steel bulkheads and inner wings, not sure whether he makes the outer wings in steel but I imagine he would know where to get a steel wing.
1989 911 Porsche Carrera
Land Rover Series
Defender 90 SW
V
V
Thanks, both - VSM was my thought too, but I believe (=need to confirm) that he doesn't do outer wings. My previous +8 ended up with a VSM back panel (following an altercation with barriers at Harewood) and it was a real high quality item.
vbalddave
Red 1993 +8 4.6
North Yorkshire
Do bent cars ever get repaired at the factory?
Apologies for thread hi-jack, just curious.
+8 4.8
Drive on the Wild Side
I have seen a couple being rebuilt after altercations. Not sure if they are still doing it, I expect the TM Mole will know. grin2
Adrian
Only the newer cars....there's a Roadster being rebuilt in the chassis shop as we speak. It had a severe side impact. The factory does make new wood frames for older cars, restoration or repair and I've seen a fully panelled older body being built in the past.
Dave,
Here is a comparison: green 1990, original wings, cream 1989, Superform wings.
wings
You could try the original manufacturers: www.vintagewingsandrads.co.uk
Fjemog
1993 Plus 8
V
V
Meabh and Fjemog
Thanks for both of your contributions here - the shapes between steel and alloy do appear slightly different, and knowing this would drive me nutty, even though I could not see both sides simultaneously (in spite of what my offspring say, I'm not THAT swivel-eyed).
Vintage Wings and Radiators look worth a punt!
Dave
vbalddave
Red 1993 +8 4.6
North Yorkshire
