11 members (DaveW, CRL, hillclimber, moggin, TeddyAds, +8Rich, sewin, Ncik P, verysideways, Steve +8, jbk),
207
64
Topics49,864
Posts837,570
Posts: 82 |
Posts: 22,363 Likes: 353
Posts: 22,363 Likes: 353 |
They should arrive with rubber bushes inserted.
Posts: 82 |
The rear springs arrived yesterday One is higher than the other So i believe the highist one is on the driver side and the other on the passenger side But what is the front side and the back side as they are not symmetrecal ?? Gr tom
Posts: 82 |
New style suplex rear leaf spring with 4 leafs From bushes to middle One side 52 cm and other side 58 cm Is that normal ? By the way i only unwrapped them And did not started the job 😂😂😂
If the difference between the centre of the front bush and the locating dowel for the axle is really 6 cm then you need to contact the supplier. But do you mean mm?
Posts: 82 |
front bush to middle 52 cm rear bush to middle 58 cm by middle i mean the point that holds the plate that holds the u bolds that attach to the axle ordered them in malvern on chassis nr
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Did you get the new a-symmetrical ones to stop roll up?
Richard 1976 4/4 4 Seater
Posts: 6,958 Likes: 117
Posts: 6,958 Likes: 117 |
Did you get the new a-symmetrical ones to stop roll up? I stopped roll-ups four days ago and now use a vaping tank.
Posts: 82 |
Yes But still no answer to my quetion 😂😂
Probably as you are the first on here! PJB might know. Looking at the MMC photos here I would not expect the low point to be in the centre due to the construction. BUT I am no expert! I would be more concerned I fitted them the right way around!
