7 members (+8Rich, Alistair, IcePack, ScotiaSteve, Player99, Burgundymog, MATTMOG), 156 guests, and 64 robots.
+8Rich 77
DaveW 51
Topics49,864
Posts837,576
tom+4 Offline OP
sorry rubbers
They should arrive with rubber bushes inserted.
tom+4 Offline OP
The rear springs arrived yesterday
One is higher than the other
So i believe the highist one is on the driver side and the other on the passenger side
But what is the front side and the back side as they are not symmetrecal ??
Gr tom
tom+4 Offline OP
New style suplex rear leaf spring with 4 leafs
From bushes to middle
One side 52 cm and other side 58 cm
Is that normal ?
By the way i only unwrapped them
And did not started the job
If the difference between the centre of the front bush and the locating dowel for the axle is really 6 cm then you need to contact the supplier. But do you mean mm?
tom+4 Offline OP
front bush to middle 52 cm
rear bush to middle 58 cm
by middle i mean the point that holds the plate that holds the u bolds that attach to the axle
ordered them in malvern on chassis nr
Did you get the new a-symmetrical ones to stop roll up?
I stopped roll-ups four days ago and now use a vaping tank.
Best Regards
Lang may yer lum reek
tom+4 Offline OP
Yes
But still no answer to my quetion
Probably as you are the first on here! PJB might know.
Looking at the MMC photos here I would not expect the low point to be in the centre due to the construction. BUT I am no expert!
I would be more concerned I fitted them the right way around!
