8 members (uvk33n, Lance, Image, Hamwich, Ian Wegg, banbury, Morganmike, rossocorsa),
226
44
Topics49,914
Posts838,189
Posts: 462 |
We installed the new upgraded Centa compensator this weekend. Step by step instructions to follow.
Please check out my post on engine and transmission removal that will bring you to where we are in disassembling the original HD compensating sprocket design.
updated to the newer Centa compensating unit
JV Sclafani Boca Raton, FL '13 M3W Metallic Orange Pearl 128CI Steered by Empire - Riding on Ohlins
Posts: 462 |
Step one: Remove compensator housing using an Allen wrench. http://postimg.org/image/ca63yc0b3
Posts: 462 |
Step 3: Remove crankshaft shaft spacer (will not be reused) http://postimg.org/image/76jfnvekv/
Posts: 462 |
Posts: 462 |
Posts: 462 |
Step 7: Install Centa compensator with the stator cover by slipping the stator cover over the coils as it slides onto the crankshaft. http://postimg.org/image/6v6kounin/Using the washer, star lock washer and nut to lock it onto the crankshaft. http://postimg.org/image/jb3ailgun/ We torqued the nut down at 100 ft lbs. http://postimg.org/image/f38i9uff3/
Posts: 462 |
Step 8: Reinstall the compensator housing back onto the S&S block.  We first cleaned up the treads going into the S&S block.  Then bolted back on the housing. http://postimg.org/image/jdn65fki7/20 ft lbs of torque
Posts: 462 |
Step 9: Press out the original shaft from the flywheel backplate . (will not be using the old shaft) Note to Press new pilot bearing into the new shaft end. Do this before you press the shaft into the flywheel backplate. (The picture show the new pilot bushing installed already before we press it into the backplate)  Pilot Bearing Part Number: Ford of Europe BEARING NADELLAGER 82ET 7600 DA 1 596 468 You will need a large press to do this work.  http://postimg.org/image/beneo3urz/
