6 members (nick w, Mike D, Hamwich, John V6, KennethM, Dek), 364 guests, and 23 robots.
+8Rich 101
John V6 63
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,196
Georgetoad, woolfie
JVS Offline OP
We installed the new upgraded Centa compensator this weekend. Step by step instructions to follow.
Please check out my post on engine and transmission removal that will bring you to where we are in disassembling the original HD compensating sprocket design.
updated to the newer Centa compensating unit
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
JVS Offline OP
Step one: Remove compensator housing using an Allen wrench.
http://postimg.org/image/ca63yc0b3
JV Sclafani
Boca Raton, FL
JVS Offline OP
Step 2: Remove stator cover (will not be reused)
This took some time to rock it back and forth to get it off.
(using a large channel lock and a couple of small hook pullers)
http://s19.postimg.org/d676rizdf/2_Remove_stader_cover.jpg
http://postimg.org/image/qun6t5v9r/
Be careful of the copper windings behind the stator cover.
http://postimg.org/image/lafaw9lsf/
JV Sclafani
Boca Raton, FL
JVS Offline OP
Step 3: Remove crankshaft shaft spacer (will not be reused)
http://postimg.org/image/76jfnvekv/
JV Sclafani
Boca Raton, FL
JVS Offline OP
Step 4: Remove old original crankshaft seal
http://postimg.org/image/wwutjnjpr/
http://postimg.org/image/w8lz0pkzz/
JV Sclafani
Boca Raton, FL
JVS Offline OP
Step 5: Install new Morgan Crankshaft seal
Part Number K130024
http://postimg.org/image/n7c10ucgf/
http://postimg.org/image/ykykc1mz3/
JV Sclafani
Boca Raton, FL
JVS Offline OP
Step 6: From the new Centa Compensator Kit -
Attach new Centa stator cover to the Centa crankshaft
housing using the six bolts that come with the kit.
We had clean up the treaded bolt holes to make it work.
http://postimg.org/image/a5qcazo27/
http://postimg.org/image/4a101by4v/
We torqued the bolts first to 15 ft lbs of torque and then finished up at 20 ft. lbs. of torque.
http://postimg.org/image/e4njttcpb/
Note to all: always clean up any thread parts first to make sure all threaded areas are clean and right.
http://postimg.org/image/ra31zx6kv/
http://postimg.org/image/3tb715kzz/
JV Sclafani
Boca Raton, FL
JVS Offline OP
Step 7: Install Centa compensator with the stator cover by slipping the stator cover over the coils as it slides onto the crankshaft.
http://postimg.org/image/6v6kounin/
Using the washer, star lock washer and nut to lock it onto the crankshaft.
http://postimg.org/image/jb3ailgun/
We torqued the nut down at 100 ft lbs.
http://postimg.org/image/f38i9uff3/
JV Sclafani
Boca Raton, FL
JVS Offline OP
Step 8: Reinstall the compensator housing back onto the S&S block.
We first cleaned up the treads going into the S&S block.
Then bolted back on the housing.
http://postimg.org/image/jdn65fki7/
20 ft lbs of torque
JV Sclafani
Boca Raton, FL
JVS Offline OP
Step 9: Press out the original shaft from the flywheel backplate . (will not be using the old shaft)
Note to Press new pilot bearing into the new shaft end.
Do this before you press the shaft into the flywheel backplate.
(The picture show the new pilot bushing installed already before we press it
into the backplate)
Pilot Bearing Part Number:
Ford of Europe
BEARING
NADELLAGER
82ET 7600 DA
1 596 468
You will need a large press to do this work.
http://postimg.org/image/beneo3urz/
JV Sclafani
Boca Raton, FL
