8 members (uvk33n, RichardV6, Piloto, Graham, G4FUJ, Morganmike, nick w, MOGDave, Hamwich), 227 guests, and 35 robots.
+8Rich 101
John V6 62
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,192
Georgetoad, woolfie
JVS Offline OP
Step 10: Take out the original shaft bearing (will not reuse)
You first have to get the snap ring off before pressing out the bearing.
http://postimg.org/image/4s0quxd3j/
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
JVS Offline OP
Step 11: Press out the old shaft bearning
http://postimg.org/image/psqsfuglr/
JV Sclafani
Boca Raton, FL
JVS Offline OP
Step 12: Press in the new bearing that goes with the new shaft from the upgraded Centa Kit.
http://postimg.org/image/iur9nn7v3/
The Centra kit has a different design along with a different shaft size.
Part Number:
SNR
5210.ZZG15 (ZZ)
JV Sclafani
Boca Raton, FL
JVS Offline OP
Step 13: Install the new snap ring that holds the bearing in place.
http://postimg.org/image/iyl33wdcf/
JV Sclafani
Boca Raton, FL
JVS Offline OP
Step 14: Press in the new shaft into the new bearing
http://postimg.org/image/vehsxn6of/
JV Sclafani
Boca Raton, FL
JVS Offline OP
Step 15: Attach the Centa inner rotating rubber carrier on the crankshaft drive spindle using the "key" into the key slot.
http://postimg.org/image/qv5kc4osv/
We let the rotating metal part warm up in the sun so it was easier to slip onto the shaft.
Install the large metal washer with bolt locking the rotating part onto the drive shaft.
Torqued the bolt to 20 ft lbs
Remember to use some kind of thread lock on all (most) the bolts
Lock tight everything!
JV Sclafani
Boca Raton, FL
Online NoMood
Thanks again for all the information JVS, it may come in very handy one day. Just one small thing, the company that makes the drive is called Centa, not Centra.
JVS Offline OP
Step 16: Install rotating compensator into it's housing.
This is where you add the four rubber isolators into the four cups that hold them as you slide the whole assembly into the compensator housing.
http://postimg.org/image/tuhiwd4lr/
We used some grease to hold the rubber isolators in place in the rotating cups.
JV Sclafani
Boca Raton, FL
JVS Offline OP
Step 17: bolt up the compensator back plate.
Making sure as you push it closed that the four rubber isolators are in the cupped part correct.
We changed out these soft allen headed bolts for something more substantial.
Note the one head with the nice haircut, I mean where we had to die grind a large slot in it for using an impact wrench/driver to get s good grip on that countersunk bolt.
Torque the bolds to 20 ft lbs
That's it for building a new compensator.
Now you are ready to attach the flywheel !
JV Sclafani
Boca Raton, FL
JVS Offline OP
thanks for the spell check!!
JV Sclafani
Boca Raton, FL
