4 members (Paulxj, Clipper, TrickieDickie, BobtheTrain), 239 guests, and 90 robots.
Topics49,847
Posts837,391
DazMog, The Impaler, tlchzj79
Page 1 of 10 1 2 3 9 10
#316271 02/11/15 05:45 PM
Laurens Offline OP
I been just informed that one other Empire kit broke.
So far I know this is the third kit which broke down.
Again with no serious accident but I have seen pictures and to me there is only one conclusion : This can kill you !
Will update more later.
www.m3w-jungfrau-treffen.com
Omg not good news at all??
An experienced M3W-owner won't be surprised at all...
Just apply Murphy's law ....
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
The empire strikes back ? hide
Seriously though, that's not good news.
Giles. Mogless in Paris.
In what way has it failed, the track rod end risers? If this is the case I would say that the "Comfort Kit" style modification for the track rod ends is the safe way to go. Lucky for me my car now has the latest front hubs with the raised steering arms and the Empire top wishbones.
JVS Offline
I had a Empire failure where a bolt broke off where the steering rack end meets the turning part of the suspension.
the bolt did not fit flush.
it was an installation problem where the Empire part needed to be slimmer to fit flush on top the steering arm.
All good now.
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
Laurens Offline OP
Originally Posted By planenut
I what way has it failed, the track rod end risers? If this is the case I would say that the "Comfort Kit" style modification for the track rod ends is the safe way to go. Lucky for me my car now has the latest front hubs with the raised steering arms and the Empire top wishbones.
Correct ..... riser broke off again.
And this time they where fitted correctly !
Try to post pictures later.
This news has been passed on to Bill at Empire, at the moment, I understand, he is trying to find out what has caused this to happen.
He has had these risers tested previously, and tells me they have resisted a lateral force of 3 tons and as this amount of leverage is unlikely in the Three Wheeler, he cannot understand why any should break. The design is a standard industry practice and has been around for years, and as long as the taper is fully fitted into the steering arm and the shoulder is in contact with the base, with the nut tight, and checked periodically, it should be fine.
However, if anyone has any doubts whatsoever about their risers, please take them off and re-fit the original track rod ends, until a solution is found.
In the meantime, I would be grateful if everone using the original risers would please pm me so we can stay in contact.
Laurens Offline OP
[img]http://s1244.photobucket.com/user/nadvys1/media/IMG_20151101_111242_zpshtj5be6e.jpg.html[/img]
[img]http://s1244.photobucket.com/user/nadvys1/media/IMG_20151031_123013_zps89yxd4om.jpg.html[/img]
Is it common to have a taper fit bolt tightening down a shouldered fitting? Seems like the two would interfere with each other. Was it hand torqued or assembled with a powered impact tool? If it pulled in tight to the taper, then any clearance remaining between the shoulder and steering arm would stress the bolt right where it looks like the failure occurred, wouldn't it?
Scared stuff!
Bill in FtL
