8 members (JohnHarris, Mats, Montegue, stumog, Gordon D, Image, John V6, TalkMorgan), 376 guests, and 82 robots.
Topics49,848
Posts837,408
DazMog, The Impaler, tlchzj79
#319293 15/11/15 01:34 AM
alan m Offline OP
I was wondering if anyone in Australia has taken off the moustache and cam cover and
If so what size bolts were used I assume shorter bolts would be needed for the rocker cover and cam cover.What would be the best air cleaner to use? satandard or after
market ,assuming the mixture would remain ok.
I have checked on this site but how is the oil level checked?i can see a level plate
about halfway down when I remove the cap is this upper or lower ,level the handbook
mentions a dip sticthank you
Bravo. thumbs
Living proof that what saves Australia from the nanny state tendencies of it's government is the bloody minded contempt for authority that lies deep in the heart of many an Aussie. Go for it. cheers
Giles. Mogless in Paris.
Hi Alan
Yes you will just need to use shorter bolts the chrome head ones are available from any Harley Davidson service center.
The best result would be from the S&S stealth air cleaner kits for the Xwedge. There are a number of combinations the Airstream Cover fits the best.
Enjoy.
There should be two oil level plates in the tank visible through the filler, a high and low level. Shine a torch in and hopefully the low level one will be just visible through the oil that is in line with the high level tab. Check the oil level a few minutes after running the engine, to scavenge the oil back to the tank. Good luck with removing all the ugly bits on the Aussie M3W.
Please take and post pictures of what you remove, some of us would love to see them!
kirkusblog.com
1952 Ford 8N
Go for it
I was wondering if, with exception of the Aussie bits mentioned above, whether the Aus M3W would be available in the uk.
I'm making a change to my "European model", ordered the slightly higher roll hoops (Aussie Spec) for my M3W.
They'd be installed by now, but MMC sent me two equal roll hoops ... as in ... two roll hoops for the same side of the 3W, and none for the opposite side. laugh2
2010 Morgan +4
2014 M3W Brooklands
To be raced
Could someone with the later oil tank please measure the distance between the bottom of the tank and the top oil level indicator, as I have removed my dip stick so as to install a large penny washer to keep the rubber washer in place and stop it from falling into the tank.
Either that or I might just fit a sight glass on the side of the tank.
Mine is 4 1/4" from bottom of oil tank to high level , low level is half inch below that.
