7 members (JMcL, Zach, RibbleAdventures, Socalm3w, Rovert, Ruut Bianchi, John V6),
319
34
SORN
New
Topics48,367
Posts813,406
Members9,215
Posts: 1,075 |
Something like this may work as long as the thru bolt is made from strong enough materials, such as they say they are now. These are the parts. This is the assembly on the steering arm. This would keep the taper so the thru bolt would be seated properly and would "self adjust" to each individual steering are Morgan made, albeit they're all slightly different. The sleeve would then be held in place with the heim joint and a top nylock nut. Tighten the bottom thru bolt first to lock it in place and then put on the sleeve and heim joint to be tightened. This may be what one of the other guys said and I thought that's what I understood. As I said earlier, I would not have a problem or concern with the plain grade 8 through bolt like JV has done, but for the guys that want that "extra" bit of security, this option may be better suited for them. But again it all boils down to the strength of the thru bolt as it is NOW a manufactured part, not a store bought part. DISCLAIMER:
I do not know the true dimensions of the Empire parts, so I just started with a .5" thru bolt on top with a .38" thread on the bottle. I also used a taper spacer of 2" long. True dimensions of the Empire parts would have to be substituted for my parts if someone when ahead to make these parts.
Dan
Posts: 25 |
Note to Dan Lockwood:
Basically your drawing is what I had in mind, except the top of the bolt would have a socket for an Allen wrench to hold the torque while tightening the nut at the tapered end. Alternatively, the top could be ground to allow a box end wrench to be used instead of the Allen wrench Might be cheaper), but the finished size would need to be small enough to allow the top nut to slide over it to catch the threads below.
I haven't seen the new setup with the top brace, but that sounds like a possibility as well.
Bill in FtL
Posts: 215 |
I have asked for the price of new pivots from Morgan. This would then avoid the need for risers as the new model as i understand is already at the correct height. I have lost confidence in the actual setup with my small mishap....
Posts: 572 Likes: 2
Posts: 572 Likes: 2 |
Dan,
I think your arrangement is a distinct improvement to the original Empire kit. I still think the shear stress levels on the stud, at the top of the steering arm/bottom of the spacer are going to be very high. I think the only way round this other than a top brace, would be to weld the spacer, once installed, to the steering arm. The problem with this is how would that amount of heat affect the characteristics of the steel of the steering arm. Back in the late 60's early 70's, we used to have constant problems with the steering arms bending on our racing 4/4. You would start a race with the wheel alignment correct and finish with about 2 inches of toe in.
Posts: 572 Likes: 2
I have asked for the price of new pivots from Morgan. This would then avoid the need for risers as the new model as i understand is already at the correct height. I have lost confidence in the actual setup with my small mishap.... You need to change a bit more than the pivots. I was quoted around £1250 for all the bits required this summer.
Posts: 398 Likes: 1
Posts: 398 Likes: 1 |
I have asked for the price of new pivots from Morgan. This would then avoid the need for risers as the new model as i understand is already at the correct height. I have lost confidence in the actual setup with my small mishap.... Hi nadvys I looked at this myself as I was advised not to use the risers as they wouldn't pass compliance check in NZ. As well as the new pivots you will need new mudguards! I took the easy and cost effective route and installed the spax adjustable front shocks. Then lowered front until the steering arms were just about level. Ground clearance is still adequate. I have left the rear as was, which gives a slight nose down attitude Cheers, nigel
Posts: 215 |
new mudguards, easy way to save on weight...
Posts: 712 Likes: 8
Posts: 712 Likes: 8 |
A more humble response from Empire was required!!!!! You're 1000% right ! To my opinion the people from Empire need to be ashamed immensely !!Me, my wife, and our dog can call ourselves very lucky that we're still alive. This is the most dangerous construction, special on a car like this with ZERO protection. You would think you get a very quick email from Empire that they aware of the problem and an advice NOT to drive any more meter with this stuff. And they would tell you that they working on a safe solution as soon as possible. But NO, even till now you hear nothing from them, they only say that the breaking forces need to be extremely high till it breaks and thats not possible with a M3W. (see the post of Paul Jacobs). That's the same as telling long cancer can't come from smoking. When I got my risers, the ones on Gulf fitted like it should be. But in my wife's car they didn't fit at all. I got the recommendation to go to a local machinery shop and let them make the tapers smaller ! How much ? Nobody know. This because MMC uses two different sizes of taper holes ! So will my new machines tapers fit the hole ? How much chance you give me ? Yes the solution which Dan Lockwood discribes could be a better solution (but I'm not an engineer). To mine opinion the safest way is to use the comfort kit from MMC. Empire charged me a lot of money for two VERY UNSAFE products. If I look to the solution who Dan describes this would cost Empire only pennies. The postage would be almost more expensive for them Empire you're very lucky that no casualties are (till now). And Empire like I said in the beginning you need to be ashamed immensely with this behavior. Selling very unsafe products, not sending emails out after you found out ( so far as I know the first who had this was Black Adder beginning 2015 or even 2014 and you asked him to keep it quiet ), and secondly not providing us with a free upgrade and replacement.
Posts: 1,075 |
Laurens, you are correct, the simplest thing to do would be to just use the Comfort Kit from MMC and go about your driving fun. I do have a question and I think Molly said it in her write up many months ago, but the upper top plate support from the heim joint on top of the MMC spacer, does this just go under the upper ball joint? I'm assuming that's a yes. If so, do you assemble everything with the MMC new top support plate loosely held in place with the ball joint not tight while you tighten the thru bolt on the steering parts, and THEN tighten the ball joint back down? My only reason to do the quick sketch of a "possible" replacement for the Empire kit was to offer another solution in lieu of going to the MMC comfort kit. But with everything as its turned out, the MMC kit is probably the safest and proven best "fix" for the poorly designed Empire stud spacer assembly. Has anyone measured the taper of the steering arms on a M3W? If we knew the upper wide diameter and the lower smaller diameter, I could throw it into AutoCAD and tell you what it is. Of course the thickness of the steering arm would be needed. Most tapers as I've seen are 7 or 10 degrees. Usually 7 on the steering and 7 or 10 on ball joints; at least on this side of the pond... Again I only tossed out the alternative concept as something to think about, not as gospel. Not having any skin in the game, my thoughts are usually irrelevant at best... As one last thought, on changing over to the new M3W front spindles, why would MMC make the new spindles with the newly higher positioned steering arm differently so the front inner fender brace mount would have to be a new design? It would obsolete their stock and they would now have two styles of front fender braces. If someone were to ask me without any previous knowledge, I would "assume" that the steering arm was raised on the spindle upright to be in correct alignment with the rack gear outer tie rod AND the fender brace mount would be designed to stay in the same relative location as it was before the relocation upward a couple inches. But as you guys know, MMC does not always do things in a logical manner. I can see front spindles costing a bunch of money and if its only for the purpose of relocating the steering arm to retro fit older M3W's, it would not be worth it to me to do the new style spindles. IF the change requires additional fender braces, that's even worse. The old spindles could make some interesting book ends though!
Dan
Posts: 7,363 |
A more humble response from Empire was required!!!!! You're 1000% right ! To my opinion the people from Empire need to be ashamed immensely !!Me, my wife, and our dog can call ourselves very lucky that we're still alive. This is the most dangerous construction, special on a car like this with ZERO protection. You would think you get a very quick email from Empire that they aware of the problem and an advice NOT to drive any more meter with this stuff. And they would tell you that they working on a safe solution as soon as possible. But NO, even till now you hear nothing from them, they only say that the breaking forces need to be extremely high till it breaks and thats not possible with a M3W. (see the post of Paul Jacobs). That's the same as telling lung cancer can't come from smoking. When I got my risers, the ones on Gulf fitted like it should be. But in my wife's car they didn't fit at all. I got the recommendation to go to a local machinery shop and let them make the tapers smaller ! How much ? Nobody know. This because MMC uses two different sizes of taper holes ! So will my new machines tapers fit the hole ? How much chance you give me ? Yes the solution which Dan Lockwood discribes could be a better solution (but I'm not an engineer). To mine opinion the safest way is to use the comfort kit from MMC. Empire charged me a lot of money for two VERY UNSAFE products. If I look to the solution who Dan describes this would cost Empire only pennies. The postage would be almost more expensive for them It seems this is relevant: You are more than welcome Nik, sorry about the instructions, Bill and I modeled them on doing my car initially, and as we know all cars are slightly different, anyway I'm really pleased it went on without drama, and more importantly, the results are good.
I don't think anyone has been unhappy so far, and I know that Bill is so confident that he has effected an improvement that he would be prepared to refund the cost if someone didn't like it, so far not one person has asked for their money back. PaulJ you were responsible for aggressively marketing this kit on TM and I think you now have a responsibility to contact the manufacturer and find out the definitive position and advise what he is willing to do to rectify the situation for the people who have bought this Empire kit; based on your repeated recommendations. We await your reply with interest and I will ask that Simon sends you this post by email too. Brian
