7 members (Brummie Steve, DaveW, Arwyn Williams, Montegue, TBM, Cerberas, jbk), 213 guests, and 88 robots.
Sagging Hood
Topics49,858
Posts837,464
Page 1 of 6 1 2 3 4 5 6
#320232 19/11/15 08:41 PM
Smaug Offline OP
Now its my turn to replace a windshield envy Yesterday I noticed some cracks on the Passanger side Plexi Wind screen... I ordered a replacement screen at my Morgan
Dealer, and want to fit it by myself. Does any of you have this done before, are there any 'how to' instructions on this forum?
All help welcome sos
Cheers,
Georges
Only instructions that I've seen are for the Fairbourne Carriage replacement screen - but they look like a good guide to what is required even for fitting standard replacements.
ZK-Mog
ZK-Mog
Smaug Offline OP
Thanks Philip & Calum, that was the help I needed thumbs ...The instructions from Fairbourne Carriage are perfect for the job...
Cheers,
Georges
Be careful not to scratch the paintwork when removing the old screen/fitting the new. The screen is under tension and invariably scrapes the sides of the slot.
Don't forget to seal round the screen with silicone to finish the job off. Fairbourne don't mention this. A small plumbers repair tube with the cap cut will give the desired control and amount required.
M3W 'The Mapmog' Built June 2015
Hi Smaug, my passenger side screen has crazed and needs replacement, how much did yours cost.
I don't know weather to replace with standard or have new ones made out of Makrolon.
Smaug Offline OP
I will post the price as soon as I get screen...I ordered the original from Morgan, so be sure to be patient, could take some time farmer
Cheers,
Georges
Smaug Offline OP
Thanks for the advice Mapman...I will be carefull doing the job thumbs
Cheers,
Georges
When removing the screen I used a fine razor blade to cut the bond between the screen and the paint. I was told if I did not do this there was a chance of lifting some of the paint off, Of course be very careful not to score the paint with a slip. Good Luck
Smaug Offline OP
God advice hbatts, thanks for pointing out.... cheers
Cheers,
Georges
