2 members (PaulM3W, Strathaven), 226 guests, and 58 robots.
+8Rich 82
Topics49,859
Posts837,500
Jonny72
Some low cost mods for the 4/4 just completed. Started with a wonderful combined air dam and scoop from Cain. Hooked up to a 70mm pipe running up to a K&N air filter kit replacing the air filter box. I also had the ECU remapped. More horsepower. More mid range torque and more noise without the afterburner popping from sport exhaust (without manifold/Cat section conversion which is expensive and may not pass emissions test here).
Silver 4/4
Looks good, I cannot see from the photos but what stops it scooping up water from puddle splash?
Excellent Cain does some great goodies!
Neil
Very little right now except gravity. The water would have a very steep incline and I think most would be dissipated by the front grill. I will let you know.
Silver 4/4
Agreed. It's a real hand made piece of engineering. I am not going to paint it as it looks great in 'industrial' format.
Silver 4/4
Looks a good idea
I've often thought about putting that scoop on the other end of my induction hose to scoop more air in
Can I ask what the name or reference is of your silver paint?
Looks a good idea
Hi Stewart,
I believe the paint is Speed Silver Metallic
Ref: 70612 (Glasurit Classic Car Colour)
Hope that helps.
Silver 4/4
Looks like good work. My scoop and dam (the former from AeroRacking and the later home made) have made a massive difference to my running temperatures.
I also used Cains spoiler on my 2014 4/4 and used the two brake ducts inlets to duct cool air up to oe air box with K+N filter fitted. Used flexible ducting up to homemade collector box and then on to air box. Cost about 15 pounds + K+N filter 28 pounds...cost effective modification
That sounds great. Could you post or send me any pictures of the connection to the spoiler and routing to the K&N. I may have to have a rethink about the routing on mine! Rgds Garret
Silver 4/4
