7 members (Tweed19er, dogmog, RichardV6, James B W, OZ 4/4, tommog, meabh),
279
Topics48,345
Posts813,046
Posts: 29 |
Hi. Purchased my 1994 4/4 in May this year. It was fitted with brand new chrome wires and tyres. The car is off the road for winter and I thought I'd remove the wheels to carry out some basic checks and maintenance. The wheel nuts seem over tight and do not want to loosen despite hefty blows on the spanner with the lump hammer provided. I was considering getting a local engineering company to provide me with a long steel tube formed at one end to take the spanner which may give me the required leverage. Any ideas/advice very welcome. Phil
Posts: 26,748 Likes: 419
Posts: 26,748 Likes: 419 |
You can buy them on line e.g. from the MG owners club. They do get tight & need a good tap.
Posts: 3,383 Likes: 12
Posts: 3,383 Likes: 12 |
You can also buy the tool from Peter at Mulberry Fabrications, if you want to pop down to Leicester I can loosen them for you? PM first to make sure I am in then kettle will be on ;-). http://www.mulfab.co.uk/our-products/6/tools and scroll down a little
Posts: 1,943 |
I buy a lead hammer from a tool supplier. It does the job.
Button
Button
Posts: 29 |
Many thanks for the offer of help. I'll see if I can get hold of the recommended tool. Kind regards Phil
Posts: 2,774 |
Phil have a look under this on flea bay..
111844927410
Nowt to do with me but I have one and it works.
Posts: 21,868 Likes: 167
Posts: 21,868 Likes: 167 |
I've heard good reports about dead blow hammers but I've yet to buy one. At present I have a large Thor for emergencies. At home, when struggling I apply a bit of heat to the centre nut - not much but this has never failed. At the side of the road it would be different!
Posts: 541 |
Do not tightsen them to much, they usually tightsen themselves when drivning. I just use a rubber club to loden them. Ken in Sweden.
Ken in Sweden - SM7CQY Mr BRUM - Morgan Roadster 2004 Series 1 in Royal Ivory
Posts: 541 |
Posts: 29 |
Guys, thanks for the advice, suggestions etc.
Steve, I've tried the reference number you gave me for flea bay but the site doesn't seem to recognise it.
I find the Morgan wheel nut spanner design far from ideal. It needs a slight crank on the handle to provide more clearance from the wheel rim.
Anyhow I've just jacked the car up off the garage floor for winter and I'll get back to resolving this issue in the spring. Kind regards Phil
