5 members (Ritchie B, paulmog, DPEvans, +8Rich, Andy), 366 guests, and 87 robots.
Sagging Hood
Topics49,859
Posts837,476
Page 61 of 94 1 2 59 60 61 62 63 93 94
R1NGA #325301 11/12/15 12:03 PM
Q
Q
Oh ok thanks. I've put the battery tender on it as well now, just to keep the juice up to level.
Q8morgan #325306 11/12/15 12:22 PM
Battery conditioners are pretty much mandatory for an M3W in my book and they really do make the whole starting process a lot more resilient and predictable in my experience.
R1NGA #325326 11/12/15 02:47 PM
Q
Q
Very true. Now that the battery is fully charged, the starter sounds much strong.
R1NGA #325341 11/12/15 04:24 PM
+1
Q8morgan #325351 11/12/15 04:45 PM
Agreed !
Essential and easy....what's to worry about!
Neil
NeilL #325363 11/12/15 05:13 PM
Unless you have a garage without power...
I use a Battery Brain to disconnect the battery each time I put mine away and (touching ash) haven't had a problem so far.
Red Leader drive
Q8morgan #325393 11/12/15 07:01 PM
Hookup the tender by a jumper plugged into port in the dash. A lot easier than fooling around under the bonnet every time you need to hookup. The port is hot all the time. Get the plug at an auto parts store and splice it into the tender
Q8morgan #325522 12/12/15 07:55 AM
Originally Posted By Q8morgan
The weather is pretty cold now in kuwait. I've noticed it takes a few starts to get it Running when cold. It never used to do that, but I haven't changed a thing on it & didn't have a problem on the last ride a week ago
I was advised by my mechanic to switch on the ignition till the fuel pump stops whining, switch off then repeat twice & start engine. This does help on mine.
My battery tender came with a flying lead that attaches to battery & socket end is threaded to cockpit by the transmission tunnel.
TimG #325524 12/12/15 08:13 AM
+1 on this, it really does work. I fired mine up on Thursday for the first time in almost four weeks; it started immediately on the button after doing this fuel pump cycling three time and that's in an unheated garage without a battery tender.
Q8morgan #325541 12/12/15 09:26 AM
Good advice, mine hasn't been started since October.
