4 members (RichardV6, Bishmog, Bob_Price, Lordofthewings), 305 guests, and 43 robots.
John V6 68
+8Rich 66
DaveW 64
9,208 Registered Users
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,346
Posts813,057
Captain Morgan, IRWIN
#327400 22/12/15 01:35 PM
Hi All,
Has anyone converted to LED or wired up bulbs in the bullet lights on the front wing of a classic morgan. I have a 2001 4/4 and these lights don't work or are not connected.
Thanks
Phil
Regards
Phil
2001 4/4 Red
The wiring is there but Morgan couldn't connect them see this link
http://www.gomog.com/allmorgan/wingstays.html#LENS
2025 MG ZS EV aka Trigger
Formerly known as Aldermog
I had them connected on the Roadster and fitted LEDs, BUT because the inside of the casting is rough and unfinished and the LEDS radiated light mostly sideways, rather than forwards, the result was disappointing.
LEDs continue to evolve and it may be that the newer versions are more effective.
SBM Offline
I've always thought that they'd be ripe for converting. Having done the headlamps on the M3W, they simply look 'right' on todays roads..
I just replaced the bulbs with LED bulbs of the same configuration. Two seconds and done. Did the Plus 8, 4/4, Series 1 4/4. Did the rear running lights, brake lights and side markers as well. Simple thing to just replace bulbs and greatly improves safety. I have sufficient skill for that.
Cheers,
Pic of LED versus Filament Bulbs.
These came cheap from China. All sizes available.
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
I bought some 10w DRL lights from ebay and soldered them to bayonet fittings as shown in the picture below;
The wing top lights are wired so they are on with the ignition (DRL style) and are dimmed by 50% when the (dipped) headlamps are on.
The plastic lens on the front gives a very good forward light pattern even when fitted into the wing top lamps.
Hi Phil, I converted them on my Roadster two years ago and they are brilliant (so to speak) Because of the very small casting I had trouble fitting them in with my stubby fingers and not wanting to put my bare fingers onto the LED I found a Lady mechanic in my local garage that had small fingers and she fitted them with ease, hope this helps
Andy
Morgan 2009 Roadster Rolls Royce Lush Green 3.0 V6
Audi A4 Advant (some blue colour not botherd)
I also replaced bulbs with LEDs some years ago. Works OK for Me.
Button
Button
Also I have never liked the tail lites on modern Morgans. I used the old Lucas assy. Moss Motors has a LED modification that one can see in the daytime. Looks good IMO.
Button
Button
