5 members (John Winn, Jensen1960, SimonOakmere, +8Rich, Moggo), 374 guests, and 11 robots.
John V6 69
DaveW 65
+8Rich 62
Dufty, Anted4, 4199, GOFFO1965, Joske Vermeule
9,212 Registered Users
195/60 R15 for 2018 Plus4
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,348
Posts813,087
Members9,212
aeroed, DJC, James Mc, JimWhin
Page 7 of 12 1 2 5 6 7 8 9 11 12
Hi Stewart,
sorry to hear you are flooded - hope it gets sorted ASAP. As to the Morgan - worry not - mine got drenched in a flood a couple of years ago - I was driving it at thje time & discovered that Morgans float!The day after it was fine - just needed a bit of airing with carpets out to dry off. One thing - leave the brakes off & turn the wheels every so often to stop the pads rusting to the discs.
If there is anything we can do just let me know.
Phil
Ironic that Stewart probably now has more fish around him than he could ever previously imagine.
Roger
Good grief Stewart, sorry to hear about this. We are away at the moment and have just seen Croston on the news.I don't know whether it would help or if it would be of any use but once the waters have subsided if you need a dehumidifier to help dry out the Morgan I can bring it round on New Years Eve. Also, if you need help on/from that date Seb and I are ready and willing, just let me know.
Stuart
Rich Maroon and Royal Ivory (ish) +4
Thanks everyone for their good wishes
Spent the day mopping and clearing up and just finished for the evening as its starting to get dark
No electricity yet but i have met a few electrical teams and they have to go to every house and business first to make sure it's safe or take fuses out so we have been told possibly tonight if they get around to everyone
I got the Morgan out of the garage and started it, had it running for about an hour with heater on full blast while I sponged the carpets
Engine ran fine but all the boards and carpet were sodden
Just put it back in a dryish and cleaned garage
When we get some power I'll put a fan heater under to dry it out some more
There doesn't seem to be much actual damage in the house we were just left with a muddy damp layer on all the floors which we have mopped clean several times
Luckily I've got Karndean flooring pretty much throughout and it doesn't seem to have lifted
Gas hob comes in handy so we can cook something for tonight's meal and Rachel has made it cosy with candles and tea lights so just about to open another bottle of red
Cheers to all
Stewart
My commiserations etc
Originally Posted By milligoon
Worst thing you can do to a car when in deep water is start it.
It maybe worth leaving the battery disconnected for a while or remove the Main fuse in the fuse box so that none of the electrics are live (some are) so if there was a repeat and the ECU compartment got awash then no damage should be caused other than needing to dry out.
This is basically correct. Many car insurance companies on hearing the words, 'flood damage' quite likely will write the car off and not budge from doing so. At the moment, since the car is immobile and hard to get at (I know this is not strictly true) you have a good reason not to say anything at present.
I would suggest you find a nearby friend who will give you garage space in a dry brick or wood garage and allow you to run a dehumidifier. Then as soon as the flood waters recede, recover the Morgan to there - do not attempt to drive it.
On a trad, the bits that will suffer from water ingress first are the chassis cross-members as these are not sealed. Certainly with 70s chassis, there are no drain holes, but you'll not weaken them appreciably by drilling one per cross-member. When the water has all dripped out and the car has been dehumidified for a week, squirt in some waxoyl, fit some plugs to the new holes and all should be well in that respect.
Remove all the carpets. In theory, a car carpet should be waterproof, so washed and dried out might be ok, assuming no shrinkage.
Battery. Don't know where yours is. 4/4s 2 seaters and Plus 8s of the 70s have a low one and I could see water getting in here. 4 seaters though have it on the top of the bulkhead so will be unafected.
Brakes - dried out all the wheel parts hoses and pipes ought to be fine but I bet there is some slight corrosion on the disks and drums. As long as you get them dry soon, the first time the car is driven will get the corrosion cleaned off.
Oils - I'd change the engine, gearbox and back axle oil.
Petrol. The tank top ought to be high enough for no water to have got in, but I'd be trying to pump some fuel to make sure. Two gallons of Super Unleaded is my standard to dump in the tank for cars that have been standing or stored a while.
Engine - should be ok from what you say, but I would suggest you turn it over by hand with the spark plugs removed and poke kitchen paper down the plug holes at TDC to make sure no water has got in. And only then go for a start.
Not really as much work as you might think, and given insurance company attitudes, I'd be very wary of making a claim, or even letting them know.
Disclaimer, I think I've thought of most things, but no warranty or guarantee is given with the above post and it assumes the reader is competent with car mechanics.
Wow Stewart ! So sad to hear but it seems you're in (surprisingly) good spirits and getting it sorted ...
All the best thumbs cheers
2013 M3W # 793
'Mosquito'
Thanks for all the advice on the Morgan front chaps
The car was out of any water when I started it as the water had got down to trickle in the garage this morning
The Mog did take a few revs to start - the water got up to the floor level of the car just below the battery at its peak so I do think the chassis at its lowest point will have been covered
Originally Posted By Bleasers
Stewart,
If you need to get the car out and away so that it can dry and be safe I can offer you garage space near Clitheroe
Andy
Thanks for the offer Andy
There is another storm forecast for Wednesday so if it looks like we might be caught again in the same way, I will probably get the Morgan up to my works warehouse in Preston but I really do appreciate the offer
Sounds awful Stewart - good luck with the drying out.
I hope the Wednesday storm misses you.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
Hell Stewart this sounds dreadful. Fingers crossed for next weeks weather.
Andy
Laser red 4/4
Red Classic Mini Cooper Sport
Audi TT 2.0 TFSI Quatro
