12 members (Montegue, AndyGoff, Rudolf, TBM, MartO, Ricosan, Alistair, Graham, G4FUJ, JMcL, Hamwich, Image, Vansrv6),
398
83
Topics49,859
Posts837,468
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Just a strange thought. What if the back end was set up with light cart springs assisted by a weaker coil over shock absorber, and possible tramp bars. Anybody tried it.
Posts: 5,587 |
Just a strange thought. What if the back end was set up with light cart springs assisted by a weaker coil over shock absorber, and possible tramp bars. Anybody tried it. Question for a technical person at the factory on sat ?
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Parabolic leaf springs would be a satisfactory solution and have been used on many modern cars. Essentially it is one spring, so no interleaf friction, but they are a very complex thing to design and manufacture. Coils are much easier.
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
I seem to recall Dan White designed some parabolic springs for Morgans some years back. IIRC a chap called Achim Gloger tried them fitted to his Plus 8. I've not seen him on any of the forums for a good few years now, so I suspect he might have sold his Morgan.
Posts: 676 |
Parabolics can have more than a single leaf, numerous Series Land Rovers have Parabolics with more than one leaf although I believe that Transit vans used to run with a single leaf parabolic rear spring.
1989 911 Porsche Carrera Land Rover Series Defender 90 SW
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
The after-market parabolics supplied for MGB's were under-engineered and on V8's soon twisted into an S shape. Quite a lot had to be replaced. Familiar subject eh?
Posts: 1,213 |
Hasn't someone on here got some sort of air assisted rear suspension ?
Hugh
One of the four seaters as I recall.
Posts: 363 |
That's one of our Scandinavian colleagues - Soleng, in Norway? (on edit) Here's Harald (Soleng)'s original gallery post on the subject http://www.talkmorgan.com/ubbthreads.php/ubb/showflat/Number/235294/
Doug 1985 4/4 4str, Jubilee Blue
Posts: 5,440 Likes: 131
Black Rat Charter Member
Posts: 5,440 Likes: 131 |
The after-market parabolics supplied for MGB's were under-engineered and on V8's soon twisted into an S shape. Quite a lot had to be replaced. Familiar subject eh? Back in 1966 I bought a new Midget from John Sprinzel in Bayswater a well known rally driver and MG dealership. We fitted Konis to the rear with great success after the initial rear floor failure ! He designed some brackets and had them made worked a treat. He used a Midget on the Monte Carlo Rally fitted with the conversion. I was standby second driver/navigator but sadly didn't get to go.
