4 members (JohnHarris, Aeromax51, Alistair, Cerberas), 337 guests, and 94 robots.
+8Rich 86
Sagging Hood
Topics49,853
Posts837,447
JVS Offline
Got it !
wrong side of the crankshaft!
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
To easily block the centa I made a piece that facilitates immobilization
I had already made a tool to immobilize the previous torque damper and tightened the nut to 23 kg + Loctite, I can not find the tightening torque at S & S, at 18.5 kg harley he advocated for the nut Crankshaft someone knows the correct tightening torque?.
100 ft lbs torque seems very high converted kilograme (45.35 kg).
Matty Offline OP
Love the bench made from old sewing machine stand. Wonder if thats where the inspiration for the first cast black and decker workmate came from
I assembled damper Centa and paste the splines with Loctite quick metal 660.
For disassembly without problems I make an extractor for not working as a wild and anything damaging.
Torque 28 mkg (24 mkg recommended)
Wonderfull tool !
You are clearly a very clever engineer, great work.
Martin (Deano)
JVS/GLL, I'm trying to drill the compensator housing to install a zerk and am finding the housing on mine VERY hard and can't get the drill bit to bite. Feels like the housing is case hardened? Any help appreciated. PS My M3W is 2012 and compensator not noisy yet, but I'd like to be ready, Thanks
The torque damper housings are made of aluminum (duralumin), it pierces easily, check the status of your wick or the direction of rotation of the machine.
The installation of a grease can be done without removing mechanical already drilling a 20mm diameter hole in the casing to reach the torque damper.
