Topics49,844
Posts837,366
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
My problem was the rubber hose under the heat shield, the one going across Me too, fixed it myself but man that was a dangerous drive back home after I had found out... Everybody check on this! The same problem for me
Posts: 582 |
I didn't like the pressure the heat shield placed on the right side of the hose so I cut a notch to clear the hose. Don't know if it helps but makes me feel better.
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
I checked mine yesterday and all seems fine, although I did put some washers under the heat shield to lift it up slightly so as to clear the hose.
