7 members (Gordon D , rossocorsa , sprinty , TeddyAds , MJF , cerealsurfer , JohnHarris ),
258
58
robots.
Admin ,
Global Mod ,
Topics49,860
Posts837,522
Most Online1,063Jun 14th, 2026
Does anyone happen to know who makes the illuminated push button switches with the chrome bezel as used on the current models of Plus 4 and 4/4? I want to get a matching switch for the front fog lights and searching the internet I can not find anything similar.
Hello dear Peter,
it´s a German Company but unfortunately they don´t sell to privateers.
MMC should have such a switch readily available (i have used them more than once on my projects)
+ they have the "correct" symbol for the front fogs and the fitting connector attached
Hope that helps....
It doesn´t matter how fast it becomes, but how it becomes fast.
2015 Roadster 3.7
Check with Morgan dealers if they have changed any of these switches for a different type, and kept the old push button ones in there stock. I recently purchased four second hand ones for a fraction of the cost. Also if people have had new dash panels they most probably changed the clocks and switches as well. Good luck. Jim.
good source could be Morgan Park Hamburg as they sell a lot of their own dashboards w/o the standard buttons. They are helpful on the phone.
I believe the switches are built from the EAO 61 and 71 series.
Roger 2011 Plus 4
Maybe even more at Matthias Kauffelt, Mannheim?!
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
You are right, he could play draughts with them
Hi peter. try this link as a number of friends have used them on their Mogs.
http://www.demon-tweeks.co.uk/
The Car is fast the sky is blue just be safe in what you do
Peter, the pcb failed on my 2006 Roadster so I have 4 spare switches though the bezels are ali not chrome so you would need Cain's upgrade. They are though fixed at the front as normal but also fixed to the PCB by a connector block at the back which is soldered to the PCB. I will happily remove one & post it if it helps. John
