2 members (JoeSpeetjens, Laurens), 161 guests, and 71 robots.
+8Rich 76
Topics49,860
Posts837,520
Jonny72
#337585 02/02/16 11:48 AM
Does anyone happen to know who makes the illuminated push button switches with the chrome bezel as used on the current models of Plus 4 and 4/4?
I want to get a matching switch for the front fog lights and searching the internet I can not find anything similar.
Hello dear Peter,
it´s a German Company but unfortunately they don´t sell to privateers.
MMC should have such a switch readily available (i have used them more than once on my projects) innocent + they have the "correct" symbol for the front fogs and the fitting connector attached
Hope that helps....
drive 2015 Roadster 3.7
Check with Morgan dealers if they have changed any of these switches for a different type, and kept the old push button ones in there stock. I recently purchased four second hand ones for a fraction of the cost. Also if people have had new dash panels they most probably changed the clocks and switches as well.
Good luck.
Jim.
good source could be Morgan Park Hamburg as they sell a lot of their own dashboards w/o the standard buttons. They are helpful on the phone.
Rog Offline
I believe the switches are built from the EAO 61 and 71 series.
Roger
Maybe even more at Matthias Kauffelt, Mannheim?!
Ruut Bianchi
Hello Peter
Maybe Car Builder Solutions will have something close to the ones you are looking for. http://www.carbuildersolutions.com/uk/electrical-billet-aluminium-switches.
2014 +4, Le Mans Blue / Magnolia
"Meg" the Mog
You are right, he could play draughts with them smile
Hi peter. try this link as a number of friends have used them on their Mogs.
http://www.demon-tweeks.co.uk/
The Car is fast the sky is blue just be safe in what you do
the pcb failed on my 2006 Roadster so I have 4 spare switches though the bezels are ali not chrome so you would need Cain's upgrade.
They are though fixed at the front as normal but also fixed to the PCB by a connector block at the back which is soldered to the PCB.
I will happily remove one & post it if it helps.
