9 members (MogOnTheMove , Lordofthewings , PaulyG , Rex_tulips , John07 , RedThree , linklaw , brownbaker , Richardllll ),
320
38
robots.
Admin ,
Global Mod ,
New
Topics48,365
Posts813,384
Members9,215
Most Online1,046Aug 24th, 2023
ok, i got a crack in the header just behind the mounting on the zylinder. its 3 cm long.
wow thats a bad one
its a "logical"(crack) one! just 2 bolts to hold the weight of the pipe, flex section, and the cat. ad all the virbrations to it, and bingo!!!
somebody has an idea what a new header costs ?
No idea, but I can get you part numbers if you wish. You would have to go through your dealer. Unless you want to go to your local exhaust fabricator and have him duplicate your pipes. That might be cheaper, faster, and you may get a better product.
thanks, but no thanks...i do know a exhaust maker. but first, my dealer has to check with malvern. then i do make a decision. thanks draggin
yes this should be a warranty repair.
Broadly £250 GBP/side. Ish.
planing the next m3w tour....8 days in june. 1100km, 4 "hotels",3 fuel stops.....lots of spectacular moutain passes! highest point is col d`iseran with 2770m. looking forward!!!
for a more detailed map, send me a pm with your email (i`ll send you a .gpx file). then go to
www.motoplaner.de and hit de button "laden/import" and insert the .gpx-file
Nice, you even figured out how many fuel stops that's real ORGANIZATION
