3 members (Jensen1960, Alistair, Image), 337 guests, and 59 robots.
+8Rich 81
Topics49,859
Posts837,501
Jonny72
Page 29 of 39 1 2 27 28 29 30 31 38 39
Originally Posted By swissghost
ok, i got a crack in the header just behind the mounting on the zylinder. its 3 cm long.
wow thats a bad one
kirkusblog.com
1952 Ford 8N
its a "logical"(crack) one! just 2 bolts to hold the weight of the pipe, flex section, and the cat. ad all the virbrations to it, and bingo!!!
somebody has an idea what a new header costs ?
No idea, but I can get you part numbers if you wish. You would have to go through your dealer. Unless you want to go to your local exhaust fabricator and have him duplicate your pipes. That might be cheaper, faster, and you may get a better product.
kirkusblog.com
1952 Ford 8N
thanks, but no thanks...i do know a exhaust maker. but first, my dealer has to check with malvern. then i do make a decision.
thanks draggin
yes this should be a warranty repair.
kirkusblog.com
1952 Ford 8N
Broadly £250 GBP/side. Ish.
thanks r1nga
planing the next m3w tour....8 days in june. 1100km, 4 "hotels",3 fuel stops.....lots of spectacular moutain passes! highest point is col d`iseran with 2770m. looking forward!!! joy
drive
for a more detailed map, send me a pm with your email (i`ll send you a .gpx file). then go to www.motoplaner.de and hit de button "laden/import" and insert the .gpx-file
Q
Q
Nice, you even figured out how many fuel stops that's real ORGANIZATION
