0 members (),
336
Posts837,277
Posts: 168 |
The drain plug on my radiator (2007 +4, plastic rad) has been weeping for a while. I have tried tightening the tap a couple of times which seemed to help.
But I'm hesitant to tighten it anymore if case I break it.
It is not a major issue but it is annoying, I thought about unscrewing the tap a few turns and putting on plumber's PTFE tape and then screwing back up.
Any thoughts or experiences?
Posts: 1,702 Likes: 35
Posts: 1,702 Likes: 35 |
Unfortunately it would mean draining but I think you would have a higher probability of success if you took the tap completely out and then wrap in PTFE tape.
Roger 2011 Plus 4
Posts: 168 |
Thanks, Unfortunately I think you may be right, I will start with the easy method first and resort to draining if it fails.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Maybe not fully draining if you could bung it and apply the tape quickly....should be feasible if you have the tape ready and get it on the thread the right way around quickly enough.
Richard 1976 4/4 4 Seater
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
Agree PTFE tape should sort it.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 168 |
Good idea, I once tried that with my central heating but the bung I made did not fit so I put my thumb over the end of the pipe, but then could not reach the new coupling I had left on the table!
Posts: 1,511 Likes: 21
Posts: 1,511 Likes: 21 |
I had a leaking plug on mine although metal rad after going over rough ground. I put some k.seal into radiiator not had a drip since.
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Your not a million miles from Leicester, if you want to pop over I have a box of several hundred O rings in a range of sizes, these kind of drain plugs normally have a rubber O ring which hardens and fails. Your welcome to grab a few of each size and take back to play if you want? I agree though PTFE is just as good and also the suggestion of KSeal is a good one. These radiators have a history of failure I am afraid although normally the top hose outlet or the overflow elbow goes first, Peter at Mulfab always recommends running the cars with KSeal added to the coolant as a safety thing. I am in all day if you want to pop over PM me and I will send address.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Good idea, I once tried that with my central heating but the bung I made did not fit so I put my thumb over the end of the pipe, but then could not reach the new coupling I had left on the table! Is that a post from Mr Bean?
Posts: 168 |
Could be, I blame my rubber measuring tape!
