0 members (), 335 guests, and 54 robots.
+8Rich 94
Posts837,276
Page 6 of 6 1 2 3 4 5 6
I'm impressed, Heinz, at your pursuit of this and look forward to seeing the outcome of your findings.
Roger
Excellent work...us 4/4 owners are watching with interest !!!
Regards
As a matter of interest, has anyone heard of anyone trying to connect the air intake into the heater intake. High pressure area etc.
I did, kind of...
But I sort of got rid of the heater box
I've just uploaded a couple of pictures into the gallery
Simon@SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Morning all, is the air-flow film this :
www.youtube.com/watch?v=uomfVKFBJ44
Cheers,
Chris
Scruffymog
Now that has set me thinking. Thanks Simon
Because I data logged everything on the Roadster I was checking the intake air temperatures
They actually dropped as low as about 11 degrees in a 14 degree ambient temperature along the back straight on the Silverstone GP circuit
Whilst you don't gain any significant "boost" from ram air effect it certainly helps when the air is being pushed in at around 150mph...
Simon@SiFab.co.uk
Simon @ Sifab.co.uk
Here is my solution for my Zetec silvertop 4/4.
There is no change between the injector manifold to the MAF sensor, from the sensor I have added an Apollo cold air intake system with air drawn in from an inlet box just forward of the heater.
So the run of ducting is close in length to the original set up ending forward facing just aft of the radiator!
The engine seems more responsive to the throttle, the performance also seems a little better (being on the Island I have not had a chance yet to put her through her paces)
David
2001 4/4 Avus blue
Heinz Offline OP
The following is about the task to get a smooth and controlled drive. It is not the wish to "transform" her into a race car, she will keep what she is. The tries are more or less a fun on it's own.
Intermediate state. First pic shows the first attempt to move the MAF sensor. The result is good with regards to the thottle response with better dosage and less throttle way. High rev power is with more ease but low rev torque is unfortunately worse than with standard tube.
I removed a plastic tube inside the MAF sensor tube of the Focus part...out of curiosity and to learn how much influence edges may have due to unwanted turbulences.
This inside the Ford part second tube eliminates sharp edges, and the effect of removing it was very significant towards the worse. Lesson learned, and I avoid sharp edges whereever possible. Because we work with cheap and several parts we have to make links between aluminum tubes and silicon hoses...producing sharp edges. Of cours the Ford Focus inner plastic tube was replaced and we rounded all the edges of our aluminum tubes. Important seems to be the additional aluminum tube inside the silicon hose which is mounted to the TB.
after treatment:
Also the ali links between hoses got smoothed.
After a first ride with the smoothed tubes inside the hoses the results are very promising also with regards to the low rev torque. As I don't want to make more than one change at a time the results are even very good now, keeping the original airbox, The only alteration: The airbox is feed with cold air from the down section front of the car since a year.
Thank you Heinz for the pics. I'm impressed. Good luck for the next development steps!
Christian
4/4 sports grey
