8 members (Bishmog, BLUE+4, DCH, Hamwich, Anonymouse, Tony Quinn, Chris Cosher, Julian BB), 408 guests, and 40 robots.
Adam12 69
+8Rich 68
John V6 53
9,215 Registered Users
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
New
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,375
Posts813,506
Members9,215
Winglad
Page 8 of 10 1 2 6 7 8 9 10
drk Offline
Originally Posted By Chris99
I've just ordered a http://www.ebay.co.uk/itm/BATTERY-LITHIU...E-/191469157564
Will let you know how it goes in a week or two.
I have it on my Caterham. No problem at all.
Morgan 4/4, Caterham Seven, Ginetta G27, TVR Chimaera
drk #340589 14/02/16 10:15 PM
thumbs
Red Leader drive
The cold cranking amps (CCA) of a battery seems to be regarded as the more important parameter on this thread. This relates to the ability of the battery to supply enough current for the starter motor to turn the engine at adequate speed for it to start, and is temperature related. Whilst important this gives no indication of how long it can supply this current.
Its the capacity of the battery measured in amp hours (Ah) that should be considered of greater importance especially given that the engine may require several revolutions before firing. Furthermore any background load when car is not in use such as an immobiliser, will be better catered for by a battery of greater capacity than the puny 30 Ah original. Suggest a minimum of 40 Ah which will typically supply more than enough CCA.
Even an 850cc Moto Guzzi V twin motorbike had a 32 Ah battery as standard.
I'm not sure this is the right way round and for engine starting CCA is the key measure.
CCA is the maximum amps that can be continuously removed from a battery for 30 seconds at 0° before its voltage drops to unusable levels. So the standard 300 CCA battery can supply 300 amps for 30 seconds at 0°.
The Ah is a measure of capacity so the standard battery will supply 1 amp for 30 hours or 5 amps for 6 hours.
So more CCA = more power delivered to the starter motor with less voltage drop and hence easier starting.
CCA also improves as the temperature rises hence as I, and others, have experienced the starting is fine in summer but deteriorates as the temperature falls.
Red Leader drive
I can see why this may seem relevant but unfortunately it only applies to a new battery that has the capacity to store enough energy to achieve this parameter. Having said that a larger capacity starter battery will typically give a greater CCA. What it will also do though is ward off the downward spiral of a marginal performance battery for the application, as is clearly the case with the 30Ah 300CCA standard one, since there will be adequate reserve of capacity for longer. This will allow more acceptable battery life as well as starting performance during that life.
Batteries particularly typical lead/acid ones, self discharge over time and then there may be the tiny but constant background load of clocks and immobilisers to account for so any increase in the stored energy (relating to capacity) after last use is an advantage.
Cold weather hits you not only with lower CCA but with the stiction of thicker oil which the starter has to overcome. My leg can attest to this when attempting a start my Velo on a cold morning wink
More on the issue here.
I had the same problem yesterday, i.e. cold morning resulting in thick oil and a 3 year old battery that was not really up to the job even when new.
The enging turned over a few times without firing and then the battery was drained to the point where it would not turn the engine over any more. This is despite being hooked to a C-TEK maintenance charger all the time it is in the garage. I connected a conventional charger to the battery and after 4 hours it span the engine over and it started easily.
I also think the question of the limited CCA capacity of the standard battery is the crucial factor and I wonder if anybody has considered fitting a second battery (of the same type as the original) and connecting it with heavy cables, in parellel with the existing battery, to effectively provide a total CCA of 600 Amps.
I think there is room under the bonnet on the passenger side to fit a second battery tray and the associated battery retaining strap and I have just been quoted £48.00 for a replacement battery so replacing the pair in the future would only cost around £100 and they combined would give the greater CCA needed.
I would welcome other member's thoughts on this.
A good idea, another option would be a little red top sealed race battery down the front of the passenger footwell which is dead space.
The Westco battery I have fitted has CCA of 400A and whilst it did not start instantly this morning did start quite easily. This battery is essentially the same dimensions as the Banner battery. However there is plenty of space above the battery so a wider battery could be accommodated by positioning it higher than the existing, this gives many more options for choosing a battery with greater capacity. I did not go this route because I thought the Westco would be direct swop but as it turned out was a few millimetres wider and required an adaptor making anyway.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
This Varta would seem a good replacement for the original as fitted by atalante83. Same footprint, in fact 1mm narrower according to spec although 60mm taller, so will probably require a strap mod as well as different terminals or adapters.
A respected brand with 33% greater capacity for under £39 delivered in the UK.
Yes it is working
Î wrap it up with isolator parts ( amiante ) for avoided too hot blow coming from oil tank
