Topics49,842
Posts837,333
Posts: 987 |
Third trip out in the new (to me) plus 8 planned for tomorrow, just a short one from Aldridge to marston green as swmbo has one of the tintops and the other is in for service. Bring on another bright sunny day like today.
Posts: 5,587 |
A little annoyed as have been advised by swmbo to take the Rav4 to Norfolk and not the beloved Mog , Hell the journey will now be very dull !
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
It was such a pleasant, if cold, afternoon I just had to take a 20 mile drive in the Morgan to Whittenham Clumps and back so that I could post a few letters 😀😀😀
Posts: 970 Likes: 1
Posts: 970 Likes: 1 |
First drive of the year today, failed as battery has died  new battery ordered so try again tomorrow battery has a failed cell ( 4 yrs old so time to bin it  ) Bet it rains tomorrow Try two, battery replaced ignition key turned Nothing. ...........  Ignition barrel part el003 self distructed wires fell out of rear bits of copper and spring on the floor ! Ah well £98 later with uncle Melvin. ... now the upside down struggle to get sheer bolts out B**gr The joy of morgan ownership So unless I hot wire the morgan I'm off the road for now so rode the honda vfr800 to mot in newtown great ride back......now to get the salt off
Magwa 1950 Allis Chalmers B tractor 2000 Porsche boxster 2014 Skoda yeti 4x4 elegans
It was such a pleasant, if cold, afternoon I just had to take a 20 mile drive in the Morgan to Whittenham Clumps and back so that I could post a few letters 😀😀😀 3,300 posts now. Do i get a badge?
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
I learned an interesting thing from PJB and Quantum the other day. Adjustable dampers should always be adjusted down a number of clicks from full hard, not up from full soft. The reason is to do with possible machining variances. Whatever the variances full hard is a fixed reference point. The actual number of clicks available to full soft may be a variable so coming back up from full soft may have a different damping setting on one side to the other..
Posts: 37,404 Likes: 977
Posts: 37,404 Likes: 977 |
Lovely 90 mile return trip over Dartmoor in the winter sunshine very bracing but enjoyable.
Posts: 199 Likes: 1
Posts: 199 Likes: 1 |
Noce run over the Derbyshire Dales to pick up a 'new' hood and tonneau. Chilly around the ears, but a nice run nonetheless (is that all meant to be one word?)
Richard S 1993 4/4 1966 VeloSolex
Posts: 3,643 |
Peter, thanks for that information, I may give that a try. I just need a couple of days with nowt on.
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
I learned an interesting thing from PJB and Quantum the other day. Adjustable dampers should always be adjusted down a number of clicks from full hard, not up from full soft. The reason is to do with possible machining variances. Whatever the variances full hard is a fixed reference point. The actual number of clicks available to full soft may be a variable so coming back up from full soft may have a different damping setting on one side to the other.. I discovered this by accident. Starting from soft, the knobs on each damper will rotate different amounts before the first click, which is a soft click. Each subsequent click gets harder. So because the first click is so difficult to detect, I click to the top, counting as I go, then click down.....................
