5 members (PaulG, MJF, Adam12, 1560, TBM), 312 guests, and 39 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,325
Members9,215
Hmm, that's interesting, it would seem that the standard Morgan connection isn't through a block at all, but with separate bullets. So my wiring has obviously been mucked about with at some point - not exactly surprising, my car had a very hard life in the years before I got it.
Cheers all
I shall get my old unit off over the weekend
I'll let you know how it goes
Magwa
1950 Allis Chalmers B tractor
2000 Porsche boxster
2014 Skoda yeti 4x4 elegans
When I removed mine I drilled through each bolt from the side. Worked well.
If its the same one as I changed on my 1972 4/4 you should be able to remove the actual switch assembly by undoing a small screw and sliding it out with no need to remove the lock mechanism.
The switch assembly then slides out and is connected to the loom by ordinary bullet connectors.
The source for the switch is from a Vauxhall Chevette or Mk 1 Cavalier.
Hope this helps
Kind regards
Arwyn
CBY Offline
Take a small steel cold chisel. Hold it quite perpendiculary to the screw axle and apply it tangential to the border of the screw head with a small angle in order to be able to unscrew when gently tapping with a small hammer. The chisel penetrates a little on the border of the screw head and turns it. Don't shear the screw head.
I don't know if it is very clear, but I succeeded to do it by this way.
Regards
2005 PLUS 4
Well,
I cannot even get to the sheer bolts as they are on top of the steering column, this would involve dash board removal !
It's a straight hacksaw job through the lock mechanism plus a careful cold chisel job.
It all has to come off as the electrics insert 'exploded ' into small pieces. All the key mechanism fell to pieces so it's a full replacement job.
The jobs cancelled this weekend as the family have all decended for my 60th birthday!
Also uncle Melvin has no stock of switches and wants £98 for one ( plus vat and postage) I think a mgb one from mgbhive at £23.90 is going to be fitted !
Magwa
You can get landrover ones off eBay that are the same and fit. You're best course of action is to drill from the drivers view through the bolts. It's what I did and it was very easy.
This may be a job for Mr Dremel.
The shear bolts are too large a diametre (at least for my) Dremel bits. There's plenty of room for a full sized drill.
5 hrs struggle ,speedo out and struggle as none of the wires fitted nor matched colourwise! !!!!!!
After a long struggle with a hacksaw blade I gave into a 3" anglegrinder
Magwa
