2 members (RichardV6, IcePack), 453 guests, and 50 robots.
+8Rich 90
Topics49,841
Posts837,323
Page 5 of 28 1 2 3 4 5 6 7 27 28
OP Online NoMood
Originally Posted By Rog G
The fuel tanks hold 42 litres which is approximately 11 US gallons
I got 42 litres = 11.1 US gallons
= 9.24 Imperial gallons
I believe you guys and it's good to know. Just reread my manual and it's 25L until "E", then 15L in reserve, so 40L total (10.57 galllons). Funny how these two capacity measurements are 25 pages apart! Never seen fuel capacity of any car or motorcycle listed that way!😜
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
The new 280mm sender said 50%, so I filled her up to see how accurate she is. Took 4.8 gallons, so if say this is the correct sender for sure.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
OP Online NoMood
So extrapolating you would have approaching 1.5 US gallons left when gauge indicated zero. I can live with that wink
ZK-Mog
ZK-Mog
Ha, I've run mine on 0% a few times for as long as i have the nerve and have yet to put more than 16 litres in. I can't be bothered changing the sender though, I'll just get braver and/or use the trip meter. It's very economic
I use the trip meter and normally fill up around the 200 - 230 mile mark. The fuel gauge goes to 0% around 130 miles or so
Typically get around 25 - 30 litres in the tank so around 10 - 15l in reserve.
I wouldn't want to run the tank much lower as there would only be about 5 litres per side and there could be a risk of picking up debris if there's any in the tank.
Red Leader drive
The red gasket that came with my 280mm VDO unit kind of squeezed out and looked deteriorated. Ordered a new one from them ( they did charge me) and its black neoprene. Just installed it.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
OP Online NoMood
Maybe fortuitous then that when I fitted mine, the supplied gasket was too thick to allow the two screws that also support the cable P clips to bite. Used original much thinner gasket instead.
Anyone know where I can get this 280mm fuel sender VDO part, p/n 224011000280G here in the USA? I've googled it with no luck?
Also is a 90-0 Ohms or 0-90 Ohms.
Thanks,
Timothy
1998 +8
SS Sport tuned exhaust
2013 M3W
Stage ll motor kit
Cats removed
I, and Dolph in Louisiana, bought it through CIPI in California. Wish I could remember the correct part number but it only uses 6 or 7 of those numbers, like the first three and last four?
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
