Topics49,849
Posts837,415
Posts: 21 |
After I reinstall a new battery som function dos not work anynore. 1. Voltmeter do not work 2. Fuel gauge do not work 3. The fuse for indicator breaks 4. Ignition lamp do not lighting before I start, but efter i had pressed the accelerator pedal the lamp go on.
I have check every fuses, all fuses are ok except indicators. Morgan Plus 8 1993
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Don't want to insult you but have you checked the polarity? - Mark terminal to earth?
You would not be the first!
Posts: 21 |
Yes I have. The car is running, and the headlight, fan works fine. I reinstall a new fuse and it break after the indicator was switch on for 8-10 seconds.
That's a strange one Hans, strange coincidence to start blowing a fuse just after a battery change, could a wire have been trapped or moved?
Posts: 21 |
I try to find out if it´s so. I can´t see any logical reason. If you have any new ideas please let me know.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Sounds like you had a voltage spike on connecting the new battery.
