5 members (ScotiaSteve, Burgundymog, asbojohn, TeddyAds, BLUE+4), 262 guests, and 49 robots.
+8Rich 82
Topics49,859
Posts837,496
Jonny72
Hans K Offline OP
After I reinstall a new battery som function dos not work anynore.
1. Voltmeter do not work
2. Fuel gauge do not work
3. The fuse for indicator breaks
4. Ignition lamp do not lighting before I start, but efter i had pressed the accelerator pedal the lamp go on.
I have check every fuses, all fuses are ok except indicators.
Morgan Plus 8 1993
Don't want to insult you but have you checked the polarity? - Mark terminal to earth?
You would not be the first!
BR Colin
Hans K Offline OP
Yes I have. The car is running, and the headlight, fan works fine.
I reinstall a new fuse and it break after the indicator was switch on for 8-10 seconds.
That's a strange one Hans, strange coincidence to start blowing a fuse just after a battery change, could a wire have been trapped or moved?
BR Colin
Hans K Offline OP
I try to find out if it´s so. I can´t see any logical reason. If you have any new ideas please let me know.
Sounds like you had a voltage spike on connecting the new battery.
Mark - No Longer driving
