0 members (), 389 guests, and 56 robots.
+8Rich 90
Topics49,841
Posts837,323
Christoph
Clock #346390 10/03/16 05:26 PM
Hi Clock, out of interest where in SOA did you get your car MOT'd.
Ian
Clock #346434 10/03/16 06:59 PM
Clock Offline OP
I actually used Allon White this time as I had to go there.
Normally I use Roman Motors (at the end of Western Road by the Gym), they are very good.
Clock #346449 10/03/16 07:29 PM
Clock, thanks for that. I use Williams who service my car.
One of the factory tour guides mentioned he used TR Autos in Bidford, however I have not heard anyone else using them.
Ian
Clock #346451 10/03/16 07:35 PM
Originally Posted By Clock
I tried to remove the plus previously, but even leaving WD40 in the well overnight they refused to unscrew. I don't want to apply too much force with the socket wrench in case I break the plugs.
Maybe I will leave them until I have to next visit a dealer!
I wouldn't leave it Clock, they aren't going to get any better or easier to come out with time. Tim is right about wd40, I've had more luck with letting some diesel sit around them, it creeps. If you get some movement, work them back in before applying too much force to wind them out. Hope it goes ok.
Clock #346456 10/03/16 07:39 PM
Clock Offline OP
You are right, cannot put it off any longer.
Clock #346457 10/03/16 07:44 PM
Not sure I can do anything more than you can, but always happy to lend a hand if you need, you aren't that far from me.
Clock #346458 10/03/16 07:51 PM
Clock Offline OP
Thanks Steve, I'll give it a go myself first (must keep learning new skills).
If I fail then I would welcome some help.
Regards Clock
Clock #346465 10/03/16 08:01 PM
Most, if not all modern engines running with a cat converter will show 0% c/o on the MOT emissions test. The HC reading is a good guide to engine health/set up as HC is hydrocarbons or unburnt fuel . If its running well it should burn all the fuel you pump in and hence a HC reading close to zero is very good.
Clock #346620 11/03/16 12:41 PM
My Roadster score 6ppm on HC vs the limit of 200 ppm. I guess that is good news.
