6 members (Mogdavid, Bishmog, Paul F, Grumpy2, Rog G, TBM), 302 guests, and 41 robots.
+8Rich 65
Adam12 62
John V6 59
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,343
Members9,215
Page 1 of 5 1 2 3 4 5
#346965 12/03/16 03:56 PM
John07 Offline OP
Just looked at the plugs today on my duratec plus 4. It's obviously been a bit wet in the void where the plugs sit. Fortunately I did vacuum everything out at each stage of the job, so not too much muck went down the plug holes!!
Time to make some sort of cover.
Cheers
[URL=http://s374.photobucket.com/user/ellison97/media/IMG_0012rs_zpsludo8ggy.jpg.html][/url]
John07 #346975 12/03/16 04:13 PM
Anti seize paste is your friend!
kirkusblog.com
1952 Ford 8N
John07 #346984 12/03/16 05:06 PM
John07,
What a sight, how long had those plugs been in situ?
Reg
John07 #346986 12/03/16 05:14 PM
And the gaps are massive, surprising the engine ran
Ken A.
Plus 4 2009 Centenary Metallic Red
Plus 8 1994 Dark Green (prev)
Honda CB100 The Big One
John07 #346991 12/03/16 05:31 PM
Years ago I made a rudimentary rain shield for both sides of the bonnet but there are some very professional ones on TM
Ken A #346994 12/03/16 05:44 PM
John07 Offline OP
Yes anti seize was used on the new plugs.
Originally Posted By lowebird
John07,
Could be from new, there's no record of them being changed in the receipts I've got. That's 8 years and 15K miles.
The gaps are only a bit over what they should be, which is .050in.
What shocked me was the height of the water level stain on the plug caps. The problem is there does not seem to be any way out for the water apart from evaporation. In the engine's natural habitat there are no bonnet vents to fill the plug trough with water.
Cheers
John07 #347076 12/03/16 08:43 PM
yes a cover is also on my project list.. have to stop the water getting in there in the first place as they don't dry out naturally very well or quickly as the plug leads ALMOST seal the hole.
Gaps have got wider using modern electronic systems, the old coil or magneto systems often needed smaller gaps. I think wider gaps offer better or fatter spark with a good electronic system and better burn characteristics than smaller gaps. Also pays to check on even new plugs out of the box as they do vary!
I wouldn't leave plugs in for more than a year, wouldn't necessarily change them but keep them 'moving'.
John07 #347079 12/03/16 08:52 PM
Interesting comments. Your advice on keeping plugs for only one year is ok but what about mileage?
A lot of us do not do so many miles. so this would be another expense every year.
So if one does, say 5000 miles a year would you advocate the same replacement period?
Ken A.
Ken A #347084 12/03/16 08:57 PM
Ken, i said in my post above "i wouldn't necessarily change them".. after only a year unless your a taxi driver they wouldn't warrant replacing on normal mileages.. but a clean and anti seize is a good idea. These can seize up in no time if you just go on mileage and on a GDI the lower threads get carbonned up as they sit in the combustion chamber, i don't like the thought of winding that out in alloy threads..
John07 #347086 12/03/16 09:03 PM
Steve, that's a good answer, i will (hopefully) whip my 8 plugs out tomorrow and test your theory.
Ken A.
