6 members (Tresco, Luddite, Strathaven, Topline123, Graham, G4FUJ, banbury),
255
33
Topics49,908
Posts838,109
Posts: 29 |
Hi. I've just removed the chrome bumpers from my Morgan as I want to refurbish the insides as they're going rusty. To do the job properly I'd like to remove the rear bumper mounting brackets but one of the nuts has rusted up causing the coach bolt to rotate. I've tried WD40 to free it up but without success. I cant get in with an angle grinder to cut off the nut. The only other thing I can think of is to purchase a Dremel but don't really want to spend the money if I don't have to. Anyone got any ideas? Phil
Posts: 29 |
Thanks Pete. Would you say this is better than WD40?
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
Thanks Pete. Would you say this is better than WD40? Almost anything is better than WD40 as a penetrating fluid: Plus-Gas, Liquid Wrench, even a 50-50 mix of diesel and paraffin. WD40 is great for cleaning and degreasing stuff, but for everything else it's pretty pants.
Posts: 1,036 |
Try a nut splitter; alternatively a hacksaw or a hacksaw blade inseted into a blade handle so the the 'bow' doesn't impede access.
Reassemble anything and everything unless internal (e.g. engine, etc) with copperslip.
Posts: 29 |
Thanks David. I hadn't considered a nut splitter. This may well be the best option as the coach bolt itself is turning and impossible to grip the domed end.
Posts: 1,036 |
Phil, consider taking a hacksaw down the centreline of the thread and nut. You should be able to remove enough metal to enable you to split the nut with a hammer and cold chisel.
Posts: 60 |
If you can get two nuts to lock together at the very tip of the coach bolt to hold the bolt tight you might be able to have a spanner onto them and another on the rusty nut and work the rusty nut back against the two locked nuts
Posts: 1,036 |
Hello Andy, I trust that you're well!!!!!
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Hi. I've just removed the chrome bumpers from my Morgan as I want to refurbish the insides as they're going rusty. To do the job properly I'd like to remove the rear bumper mounting brackets but one of the nuts has rusted up causing the coach bolt to rotate. I've tried WD40 to free it up but without success. I cant get in with an angle grinder to cut off the nut. The only other thing I can think of is to purchase a Dremel but don't really want to spend the money if I don't have to. Anyone got any ideas? Phil Phil If you want to drive down to Leicester I have a couple of Dremells and a box of cutting discs your welcome to use, coffee would be on. PM me if you fancy the drive and I will email you the address
